King Pins
13 Apr 2011 01:28 #14928 by mlines
Replied by mlines on topic Re: King Pins
The SET is £23 or £23.50 (depends on the brand I have) and includes the TWO bearings and the old seal.
THe advice on refitting the Kingpins themselves is that the wear differently.
The other threads advice on shimming is misleading.
Jimnys do not normally need shimming. The older SJs did. There is no normal shim set for the Jimny. I do a bearing shim set to help reduce wobble and these are the same shims that Suzuki supply to people with a persistent wobble on Jimny O2 Alloys.
  • jonplace
13 Apr 2011 06:39 #14935 by jonplace
Replied by jonplace on topic Re: King Pins
i've always found that when fitting new kingpin bearings and rings, when you tighten the kingpin bolts top and bottom the load is too much on the bearings
  • mcjimny
13 Apr 2011 12:52 #14948 by mcjimny
Replied by mcjimny on topic Re: King Pins
facade wrote: Under no circumstances damage the rubber seal around the swivel housing.
A new one costs as much as a small flat in Central London.
As i discovered the swivel hub seal should be replaced annually. If thats the part you are referring to, iirc they aid steering damping too. I paid about £23-26 a side off ebay from a suzuki dealer.
  • Keefe
13 Apr 2011 14:26 #14954 by Keefe
Replied by Keefe on topic Re: King Pins
No eBay APP ID and/or Cert ID defined in Kunena configurationAre these, those? ;)
K :)
  • Peter
13 Apr 2011 15:26 #14960 by Peter
Replied by Peter on topic Re: King Pins
Thanks to all, and to Martin. Good holiday I hope!
Local bearing supplier took delivery of my bearings, but their supplier sent the wrong ones. :S So apologies accepted and it will now be tomorrow.
Can't tell you how helpful this site is, and has been. :)
Big thanks to Martin and the others.
Regards
Peter
13 Apr 2011 17:31 #14968 by facade
Replied by facade on topic Re: King Pins
Where did you discover that?
If they really are that poorly made/designed Suzuki ought to make the price a shade more realistic.
Landrover ones last donkeys years and are a lot cheaper.
Time to create page: 0.188 seconds
