Front Prop clearance with Castor correction arms
- Gary Whenmouth
10 Apr 2011 18:24 #14789
by Gary Whenmouth
Front Prop clearance with Castor correction arms was created by Gary Whenmouth
Just fitted my front ORA 4.5' correction arms, however the front prop is catching the cross member which supports the gearbox.
Thinking if the best way to cure this is to fit a 25mm prop spacer to the (standard) transfer box end and raise the transfer box by 10mm to give clearance and droop to the prop shaft?
Any others got any experience with this?
- viciouspenguin
10 Apr 2011 18:34 #14792
by viciouspenguin
Replied by viciouspenguin on topic Re: Front Prop clearance with Castor correction arms
i had noticed it was kinda close on mine too, I have my old SJ tcase fitted so i guess it has changed the geometry as it doesn't seem to catch. or i havent noticed it catching yet.....
it might be worth emailing ORA to ask about it......
- Mumbo Jimbo
10 Apr 2011 19:43 #14803
by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: Front Prop clearance with Castor correction arms
I fitted my ORA 4.5" lift kit today and noticed the same. The prop was clear of the crossmember once I fitted the 35mm prop spacers that came with the kit. I fitted the spacer to the transfer case end of the prop shaft.
- Gary Whenmouth
10 Apr 2011 19:52 - 10 Apr 2011 19:52 #14804
by Gary Whenmouth
Replied by Gary Whenmouth on topic Re: Front Prop clearance with Castor correction arms
Thanks.
Looks like I need a 35mm spacer then! I only got the 4.5'' arms as i'm poor. I have 3'' springs and 1.5'' b4v spacers so 4.5'' overall.
I also found my prop splines were seized solid, so they will get a good clean up and grease while off.
Did the kit come with 2 x spacers? Not yet fitted the rears as apparently I spend to much time on Big Jimny, or under my Jimny, and not with her.
Last edit: 10 Apr 2011 19:52 by Gary Whenmouth.
- Gary Whenmouth
10 Apr 2011 19:56 #14805
by Gary Whenmouth
Just checked out kit contents and they have 2, just to answer my own question.
11 Apr 2011 16:59 #14835
by kirkynut
Replied by kirkynut on topic Re: Front Prop clearance with Castor correction arms
[quote="Gary Whenmouth" post=1480 apparently I spend to much time on Big Jimny, or under my Jimny, and not with her.[/quote]
I suffer with that but she doesn't complain when she goes offroading, then she forgets the many hours I've spend maintaining the bugger and it's like the Jimny maintainence fairies have been at it and not me!!!
Time to create page: 0.158 seconds
