Track rod ends
- mad4x4
17 Nov 2009 05:11 #1469
by mad4x4
Track rod ends was created by mad4x4
:ohmy: £50 - Ehhhhhh
Anyone do them cheaper
This vehicle is not cheap for SPARES!
17 Nov 2009 05:44 - 17 Nov 2009 05:45 #1471
Replied by mlines on topic Re:Track rod ends
Well Camskill are usually the cheapest around, but the Blueprint parts they sell are supposed to be of a standard which does not invalidate Suzukis warranty.
If you look at places like Demon Tweeks ( www.demon-tweeks.co.uk ) they do lots of Motorsport ones but these are not listed by model but by size.
Suzuki do them of course - 48820-81A00
I don't know if anyone has fitted Landrover Track Rod ends :S to a Jimny but this was certainly an upgrade that people have done on the SJ to toughen it up.
Last edit: 17 Nov 2009 05:45 by mlines.
- mad4x4
17 Nov 2009 10:51 - 26 Nov 2009 10:31 #1475
by mad4x4
Replied by mad4x4 on topic Re:Track rod ends
Ok
Some Part Numbers For Track Rod Ends
Delphi -
TA1996 - Listed as Pass Side Jimny (LH thread)
TA1997 - Listed as Drivers Side Jimny (RH Thread)
Blue Print (from Camskill.com)
ADK88724c* - Listed as RH OUTER TRACK ROD END (LH thread)
ADK88723c** - Listed as LH OUTER TRACK ROD END (RH Thread)
*Note - This one has an inbuilt Grease nipple
**NOTE - This one appears to come with out the nut to hold the taper into the HUB and doesn;t have the grease nipple or greasenipple hole.
I was unlucky and ended up with a 88724c and a ta1996
Delphi -
Last edit: 26 Nov 2009 10:31 by mad4x4.
- mad4x4
21 Nov 2009 13:31 - 21 Nov 2009 13:32 #1493
by mad4x4
As for landrover T/R ends - The Taper is different size
Last edit: 21 Nov 2009 13:32 by mad4x4.
- Baz2236
05 Apr 2010 16:24 #3039
by Baz2236
Replied by Baz2236 on topic Re:Track rod ends
Hi I know its an old thread but did you manage to find the ball joint any cheap
Does anyone know if the track rod ball joints are the same as the steering arm joints.
Thanks,
Baz
Thanks,
Baz
