Trolling the Web and Found this +3" Lift Info
05 Nov 2009 06:37 #1432
Replied by mlines on topic Re:Trolling the Web and Found this +3
I would suspet Mad4x4 is probably correct. Most lifting spring sets are not matched to the vehicle, they are just "what have we got that fits and lifts the vehicle". Some kit providers do make the effort, for example the OEM springs on the rear of a European Jimny are different each side and some lifting suppliers provide "handed" springs. The problem is that, whilst its easy for Suzuki to create springs in the first place as all Jimnys are the same off the production line this is not true of modified Jimnys.
Mine has a 3" lift, but the supplier does not know what I have done or not done to my car. I have a rollcage, front winch bumper and winch mounted in it, making it heavier than a normal car. In particular the weight of the winch and its position relative to the suspension points makes a big difference on mine, with the winch cable unwound the front of the car rises.
Therefore, I think the best answer is to fit the springs that work the best for you. Of course, the other often more key issue are the dampers and the damping rate, this can affect road holding more than the springs. But this is another argument altogether.
14 Nov 2009 14:49 #1461
by kirkynut
Replied by kirkynut on topic Re:Trolling the Web and Found this +3
I've not been on here for a bit as busy buying a house but I have to say that the reputable companies out there get their products from companies who have put some research into what should be on what vehicle to lift it with the right rate springs.
It may well be that the standard spring off of vehicle X will be the right length and rate to lift the front of a Jimny by 3 inches and the same with the rear from vehicle Y, but there is some research into what works safely. They may have been produced specifically but I'm undecided in my opinion.
I agree with Martin's comments about each vehicle being different with cages, front and rear winches and different amounts of cable on them, betteries in different places etc, however, just lifting a standard Jimny like mine is a starting point.
I have KAP's competition spec 3 inch lifting springs on mine, rated for vehicles with a winch and winch bumper on the front, these are different to their standard 3 inch lifting springs.
I know of one of the main suppliers of Jimny lifting springs in this country obtaining springs via another reputable supplier in Europe and this UK seller is exporting them themselves back out to Europe again! The original supplier has spent considerable time and effort with the manufacturers to get them right.
The thought of putting front springs on the rear fills me with fear. They are harder rated to take the weight of the engine, the rear does not weigh much at all! That will cause it to bounce all over the show, no matter what shockers you use!
I say spend the extra money and stay safe.
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
15 Nov 2009 20:15 #1464
by funkyjimny
Replied by funkyjimny on topic Re:Trolling the Web and Found this +3
www.springcoil.co.uk
used to make the springs for Explorer Pro Comp 2" lift kits, and also made the 3" springs that KrAP sell or sold at the time, who bought them through Explorer Pro Comp. Took me some digging, but in a previous jimny build i had them make some custom front springs to cope with my ARB winch bumper which held the winch out a long way forward and made the original 2" lift kit near coil bound.
They had all the tech specs of the std jimny springs, and the pro comp kit, and i had +4.5" springs made up with std rating.
Maybe this'll help.
Gary
Maybe this'll help.
Gary
- mad4x4
17 Nov 2009 05:25 - 17 Nov 2009 05:26 #1470
by mad4x4
Replied by mad4x4 on topic Re:Trolling the Web and Found this +3
Good points above ^^
Last edit: 17 Nov 2009 05:26 by mad4x4.
