Trolling the Web and Found this +3" Lift Info
- mad4x4
03 Nov 2009 17:08 - 03 Nov 2009 18:00 #1424
by mad4x4
Trolling the Web and Found this +3" Lift Info was created by mad4x4
Was trolling the net and found this
LINKY
Has any one tried this by putting front springs on Rear and putting on 2 new springs on the front.
LINKY
Last edit: 03 Nov 2009 18:00 by mlines.
03 Nov 2009 18:03 #1425
Replied by mlines on topic Re:Trolling the Web and Found this +3" Lift Info
There is also a strong "rumour" that if you put Mercedes 190 springs or Lada springs on the front this does the same.
So move the Jimny springs to the back, put scrap Merc/Lada springs on the front = job done. But no-one has yet cofrimed to me the exact truth behind this ie. exact model of Merc/Lada accompanied by pictures
- mad4x4
04 Nov 2009 10:45 #1427
by mad4x4
Replied by mad4x4 on topic Re:Trolling the Web and Found this +3" Lift Info
Intresting, worth some more research then .....
- Jamie
04 Nov 2009 15:19 #1428
by Jamie
Replied by Jamie on topic Re:Trolling the Web and Found this +3
mad4x4 wrote:
Sorry but totally dissagree with using a mish-mash of springs on a vehicle
to be driven on the road.
Completley wrong spring rates etc.
Springs are the only thing keeping your wheels in contact with the road
and yet people try to cut corners and do it cheaply.
Jamie
Jamie
- mad4x4
04 Nov 2009 18:04 #1430
by mad4x4
Just because a spring for a Merc or a Ford doesn't mean that it is not used on another vehicle. Where do you think the company's that off lifts get there springs - Custom made or just figured out that a "spring from car X" is same as a jimny spring but +2"
- Jamie
04 Nov 2009 18:31 #1431
by Jamie
Spring's are matched to a vehicle after corner weight's
are all worked out then you take into account the unsprung weight
i.e wheel's, axle's then the sprung weight chassis, shell etc.
You then create a spring using all this info not just find a car with the same length spring.
Bearing in mind what the front end of a Jimny weigh's
compared to the weight of a Mercedes.
Down to the individual at the end of the day but i personally
think it's bonkers.
JAmie
think it's bonkers.
JAmie
Time to create page: 0.296 seconds
