New Jimny
  • scottyrocket
28 Mar 2011 19:44 #14214 by scottyrocket
New Jimny was created by scottyrocket
Hi, my first post of many I hope, I just wondered if someone experienced could take a look at this advert and tell me if the fault re Smoke when starting from cold is a major issue to worry about as i'm looking at this Jimny tomorrow.
cgi.ebay.co.uk/2002-52-Suzuki-Jimny-02-M...&hash=item45f9ad5587
Many Thanks
  • biggaz
28 Mar 2011 20:35 #14215 by biggaz
Replied by biggaz on topic Re: New Jimny
cant help on the smoke issue mate but its probably a cam belt engine in that O2 edition so would be due now, check for reciepts or knock money off..
if it is a chain (dohc engine) then forget it :-) goodluck.
  • scottyrocket
28 Mar 2011 20:51 #14216 by scottyrocket
Replied by scottyrocket on topic Re: New Jimny
Do you not reccomend the chain engined then?. I think ill leave this as dont want to risk buying one that may have a serious problem. Which models are chain driven?.
  • biggaz
28 Mar 2011 21:03 #14218 by biggaz
no lol ive read that back and sounds wrong!
I meant if its chain driven you can forget the change because it doesnt need doing, which is better!
Just a heads up incase its belt driven and if it hasnt been done just knock some money off.
29 Mar 2011 05:04 #14221 by mlines
Replied by mlines on topic Re: New Jimny
With it being a low mileage soft-top I would lift the carpet in the boot and look inside and around the tool-tray in the boot floor for rust. The rain can get in and run down into the well and rust it out.
Take it for a test drive and have a good play with accelerating from 40 to 50 mph and decelerating again. Doing this will find any steering issues.
29 Mar 2011 05:07 #14222 by mlines
And I thought that traditionally a puff of blue smoke on start up was worn valve stem oil seals which is not a big issue.
The following user(s) said Thank You: scottyrocket
