TYRES - AGAIN
  • mad4x4
01 Nov 2009 13:54 - 01 Nov 2009 14:26 #1418 by mad4x4
TYRES - AGAIN was created by mad4x4
Is there a guide for tyres?
I have just bought a stock Jimny and am looking to put some MT;S ON IT. But I don;t want to go massive and loose all the gearing. Stock is 205/70R15
Looking possibly at KL71 kumho ?
Last edit: 01 Nov 2009 14:26 by mad4x4.
  • ooky_123
02 Nov 2009 21:18 #1422 by ooky_123
Replied by ooky_123 on topic Re:TYRES - AGAIN
Hi, saw your post.. Ive heard bad things about the Khumos ... although I like the look of the tread pattern personally.
Insa Turbos are generally one of the best tyre you can fit, and the special tracks seem to be regarded as the most extreme.
As no doubt you will have seen, We run Diamond backs. these are remoulds of dubvious quality but they certainly are awsome off road.
Generally speaking most people opt for the Insa's. and, if you shop around you can get them quite cheap.
if you are going to run standard suspension, then your choices will be limited and you will soon discover that the biggest problem will be grounding out.
We origionally (10 years ago) had standard suspension and when we changed to mud tyres, soon were on the phone to KAP Suzuki to order a 2" suspension lift.
03 Nov 2009 12:02 #1423 by funkyjimny
Replied by funkyjimny on topic Re:TYRES - AGAIN
you could look at 195/15 Mud terrains, or 215/75/15's which are a little bigger,both are slightly bigger than standard.
Lots of people rate the Khumo KL 71's, I prefer cheaper remould tyres such as kingpin highlander (diamond pattern) etc as not too dear to replace when damaged, not sure if theyre available in 195/15's
Gary
  • Garry
21 Nov 2009 14:28 #1497 by Garry
Replied by Garry on topic Re:TYRES - AGAIN
im running kingpin trackers mt, 195/80 15
there about 28" tall and are fine on the standard suspension
  • cz_ice
13 Dec 2009 01:43 #1593 by cz_ice
Replied by cz_ice on topic Re:TYRES - AGAIN
hi.
As far as I know there are no 205/70/15 mud tires.
However, when I went to moscow, I saw Russian made Cordiant Off Road 205/70/15. They are really good. Almost the same as BFG MT and they weight as BFG which makes them even better.
The price in Russia is about 350USD for 4 tires. BFG MT cost 850USD.
15 Dec 2009 11:37 #1599 by kirkynut
Replied by kirkynut on topic Re:TYRES - AGAIN
I run Khumho KL71's. They are Ok in mud until it gets really, really thick and gloopy and it is then that they start to not be as good as say an Insa Turbo Special Track or Amazon style patterns.
They are however a MT that is exceptionally quiet on the road and offers good grip on the road.
I would therefore recomment them to anyone who wants to go off road and do some serious off roading but has to use their vehicle a great deal on the road.
Being a new tyre rather than remould, they offer greater peace of mind when on the road too and balance up better than remoulds - ie: they can be balanced perfectly rather than roughly!
To say it is a bad tyre off road would be to do it an injustice, but it is not an extreme MT, just a normal MT.
I have to say that I started off roading about 3-4 years ago now and most people were happy with Colways and the like, which are nowhere near as good as the Kumho's.
Extreme patterns were for winch challengers only, now everyone wants them and nothing else. What do you actually need for your type of off roading and realistically, will the extreme tyres get you much further?
