SUSPENSION/TYRE/BODY LIFT
- srcars
24 Mar 2011 19:38 #13985
by srcars
Replied by srcars on topic Re: SUSPENSION/TYRE/BODY LIFT
2003 soft-top, just fitted 2" body lift and steering column was 25mm short and transfer lever wont quite go into 4wd low, Brake splitter block needs a new bracket, Everthing else ok, fuel filler ect.
- chechan rebel
24 Mar 2011 23:52 #14009
by chechan rebel
Cheers for the replys................steering & shift wont be difficult as im a welder/ fabricator. Ile have to find some longer brake lines, how much longer do they need to be?
Replied by chechan rebel on topic Re: SUSPENSION/TYRE/BODY LIFT
adamjimny wrote:
vitara_mad wrote:
viciouspenguin wrote: you'll also need to extend the steering column if you lift the body.
ive not had to extended the steering colum on mine so it maybe a case of some you do & some you don't
i haven't either
- vitara_mad
25 Mar 2011 01:42 #14011
by vitara_mad
Replied by vitara_mad on topic Re: SUSPENSION/TYRE/BODY LIFT
if you doing 3" susp & 2" body lift then +5" brake hoses will be needed
- chechan rebel
25 Mar 2011 01:48 #14012
by chechan rebel
Cheer bro........basically every inch you put in you gotta add an inch.
- biggaz
25 Mar 2011 12:18 #14044
by biggaz
Replied by biggaz on topic Re: SUSPENSION/TYRE/BODY LIFT
yeh, see Martin for extended hoses
- Monkey
26 Mar 2011 08:44 #14079
by Monkey
Replied by Monkey on topic Re: SUSPENSION/TYRE/BODY LIFT
Hey mate,
Have a read of this read thread www.auszookers.com/index.php?name=Forums...opic&t=18611&start=0
Also have a look a around that site, heaps guys from you state that are into zooks and go on trips.
Time to create page: 0.440 seconds
