SUSPENSION/TYRE/BODY LIFT
  • chechan rebel
24 Mar 2011 07:32 #13938 by chechan rebel
SUSPENSION/TYRE/BODY LIFT was created by chechan rebel
I have a question regarding this, im bout to buy a suzuki jimny 2001 model completely stock. I want to put a 80mm lift kit in + 30"x9.5"x15" tyres + 15"x7" sunraiser rims..........Will these scrape? If so..........what about if i also lift body another 2"? If i lift body is there anything else i need to modify, gear shift, 4wd shift, steering? Any help be apressiated....:cheer:
  • vitara_mad
24 Mar 2011 09:58 #13949 by vitara_mad
Replied by vitara_mad on topic Re: SUSPENSION/TYRE/BODY LIFT
when i got mine it had a 3" susp lift & 30x9.5 tyres & they was fine with just a little arch trimmed
if you do a 2" body lift you will need longer brake hoses & you will need to do a slight adjustment on the transfer lever (thats all i had to do on mine anyway)
  • viciouspenguin
24 Mar 2011 10:05 #13951 by viciouspenguin
Replied by viciouspenguin on topic Re: SUSPENSION/TYRE/BODY LIFT
you'll also need to extend the steering column if you lift the body.
  • biggaz
24 Mar 2011 12:55 #13953 by biggaz
Replied by biggaz on topic Re: SUSPENSION/TYRE/BODY LIFT
you will need hoses anyway with a lift above 50mm
  • vitara_mad
24 Mar 2011 15:58 #13960 by vitara_mad
viciouspenguin wrote: you'll also need to extend the steering column if you lift the body.
ive not had to extended the steering colum on mine so it maybe a case of some you do & some you don't
  • adamjimny
24 Mar 2011 16:10 #13962 by adamjimny
Replied by adamjimny on topic Re: SUSPENSION/TYRE/BODY LIFT
i haven't either
Time to create page: 0.158 seconds
