Brake Pipe size
- Baz2236
18 Oct 2009 16:22 #1386
by Baz2236
Brake Pipe size was created by Baz2236
Hi I am about to start my rear disk conversion after reading how martin done it, I am looking for a brake pipe kit I see they do imperial and metric size what size is best for a jimny.
Thanks,
Baz
Thanks,
Baz
18 Oct 2009 17:50 #1387
Replied by mlines on topic Re:Brake Pipe size
Metric - Jimny is all metric.
10mm fixings and (i think) 4mm brake pipe
- Baz2236
18 Oct 2009 18:20 #1388
by Baz2236
Replied by Baz2236 on topic Re:Brake Pipe size
Excellent thanks for the speedy reply Martin, another quick question for the rear disc conversion it says about using long wheel studs I have gv rims on mine would I need the longer studs. Is it like the Sj conversion where you can use the studs from the front hubs I have some of them spare if they are longer.
Baz
Baz
18 Oct 2009 18:31 #1389
Baz,
Its hard to say. If you look at your current nuts/studs is there any spare thread sticking out the end? Mine were already longer studs as it says in the text and I had 3 or 4 mm of spare thread outside the end of the nut, since the conversion I have no spare thread. Is it the Muddyzook kit you are putting on?
- Baz2236
18 Oct 2009 18:42 #1390
by Baz2236
I have a little bit sticking out maybe about 2mm I will have a look tomorrow how long the studs are compared to the SJ ones on the front hub. Yeah I will be using the muddyzook kit
- Baz2236
20 Oct 2009 18:04 #1399
by Baz2236
The sj studs are a couple of mm longer then the rear jimnys ones how much longer do the muddy zook kit recommend you need
Time to create page: 0.189 seconds
