steering woes
- sjwright
22 Mar 2011 03:48 #13777
by sjwright
steering woes was created by sjwright
Hey all
Had excessive play in my steering, and as it progressively got worse, going round right hand bends made the car feel like I was driving a boat, it didn't seem to correct itself. I was advised the steering box was the culprit and this was changed.
The play in the steering is sorted, but the weird 'boat on water' sensation is still there with the right hand turns. It feels almost as if the wheel is trailing on the passenger side. Upon looking at the ball joint there is oil there, whereas on the driver side it is not present.
On tight lock it does clunk too. Would this be CV joints or something a little more serious? My local suzuki dealership were hardly cheap when it came to diagnosing the steering box, and didn't mention anything else. Any ideas before I go back down there? Any similar experiences?
Thanks
Thanks
22 Mar 2011 06:48 #13779
Replied by mlines on topic Re: steering woes
Oil on the ball joint and loose steering, sounds like either the Kingpin Bearings or Wheel Bearing.
See....
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
www.bigjimny.com/images/documents/Changi...t_Wheel_Bearings.pdf
Then go to your favourite online store...
www.bigjimny.com/store/index.php/jimny-p...ng-kit-ntn-/p_7.html
www.bigjimny.com/store/index.php/jimny-p...ng-kit-abk-/p_1.html
See....
- biggaz
22 Mar 2011 07:58 #13780
by biggaz
Replied by biggaz on topic Re: steering woes
Ive got a clunk on full lock aswell, but my steering rod ends look a bit iffy... ? could it be that on yours aswell?
- vitara_mad
22 Mar 2011 11:09 #13782
by vitara_mad
Replied by vitara_mad on topic Re: steering woes
my steering is not very responsive either so i took it to have tracking done yesterday & they did the tracking after alot of moaning & i left there it was still no better so went home & fitted new kingpins bearings & seals & noticed the tie rods ends had alot of play in them & they never said a thing about them when they did tracking so ive just ordered some tie rod ends this morning going to pick them up the afternoon & hopefully it will feel alot better then
- biggaz
22 Mar 2011 12:13 #13786
by biggaz
is there two sets of rod ends on the front?
22 Mar 2011 12:20 #13787
Yes, there are two on "each side".
One pair on the rod leading from the steering box to the hub and one pair on the rod joining the two hubs together.
www.bigjimny.com/images/documents/changing_a_tie-rod_end.pdf
www.bigjimny.com/store/index.php/jimny-p...-rod-ends/p_128.html
Time to create page: 0.166 seconds
