Radious arm bushes
  • myers647
21 Mar 2011 20:16 #13762 by myers647
Radious arm bushes was created by myers647
Hi everyone I noticed the other day I need some new bushes on my radios arms, where is the best place to get them & how easy are they to fit.
Many thanks
James
  • supergaz
21 Mar 2011 20:39 - 21 Mar 2011 20:40 #13764 by supergaz
Replied by supergaz on topic Re: Radious arm bushes
www.jimnybits.co.uk/shop/index.php?_a=viewProd&productId=51
This is what i'm saving/scrounging up for, seems cheapest place atm for these, the originals are hard to get hold of atm from any good motor factors. And these are by far the easiest to re-insert. I drilled out my old bushes then very carefully cut/prised through the rest with a hacksaw blade and screwdriver, ideally they should be removed with a press which any good workshop will have.
Last edit: 21 Mar 2011 20:40 by supergaz.
21 Mar 2011 21:01 #13767 by kirkynut
Replied by kirkynut on topic Re: Radious arm bushes
Any motor factors that can get Blueprint stuff can get them for you.
Or Rhinorays sell them or ORA sell them.
I would get the rubber ones if you use it off road or you'll lose articulation.
  • Brian.SMC
21 Mar 2011 21:27 #13771 by Brian.SMC
Replied by Brian.SMC on topic Re: Radious arm bushes
I have a full write up with pics on here somewhere, fitting super pro caster correction bushes.
Big George gave me hand and even posed for the pictures. B)
  • vitara_mad
21 Mar 2011 22:36 #13775 by vitara_mad
Replied by vitara_mad on topic Re: Radious arm bushes
i found that andrew pages where the cheapest place for the standard bushes
  • renard38
22 Mar 2011 17:07 - 22 Mar 2011 17:11 #13804 by renard38
Replied by renard38 on topic Re: Radious arm bushes
hi,
look this if you want to buy blueprint bushes: ;)
www.bigjimny.com/index.php?option=com_ku...7&id=12481&Itemid=75
it's not difficult if you have a press:
A+
Last edit: 22 Mar 2011 17:11 by renard38.
Time to create page: 0.198 seconds
