Springs
  • little monster
23 Mar 2011 08:27 #13863 by little monster
Replied by little monster on topic Re: Springs
Do you have to remove the rubber cone thing at the top of the suspension first and does the bolt on top mount of the shocks need to be screwed down as far as it will go
  • adamjimny
23 Mar 2011 08:58 #13867 by adamjimny
Replied by adamjimny on topic Re: Springs
little monster wrote: Do you have to remove the rubber cone thing at the top of the suspension first and does the bolt on top mount of the shocks need to be screwed down as far as it will go
the rubber at top of the springs stays there unless your fitting spacers then take them off
and the nut on the shocks i just did it till it had resistance and was squishing the bush slightly so its not loose but not all the way as the bush cant do its job as the tighter it gets the harder it is loosing its damper effect
  • little monster
23 Mar 2011 09:12 #13871 by little monster
Thanks adam i will go and try to put the longer sping on now, lots of swearing to be done no doubt
  • adamjimny
23 Mar 2011 09:36 #13873 by adamjimny
no worries gotta help fellow suzuki people like minded folk n all that :)
23 Mar 2011 17:55 - 23 Mar 2011 17:56 #13892 by dirtydogz
Replied by dirtydogz on topic Re: Springs
Attachment shocks0211.jpg not found
This is richie's jimny on the Suzuki 4U forum,he moved his rear brake line bracket down lower to give him a extra 3" of slack on the hose at the back a good simple idea.B)
www.suzuki4u.co.uk/forum/viewtopic.php?t=9975
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 23 Mar 2011 17:56 by dirtydogz.
  • little monster
23 Mar 2011 19:32 #13904 by little monster
Suspension all on now thanks for all the advice, managed to get the long spring in without clamps, removed the caliper put a scissor jack between axle and chassis and wound it open until the spring went in......Simples
Time to create page: 0.978 seconds
