Springs
- little monster
22 Mar 2011 18:26 #13813
by little monster
Replied by little monster on topic Re: Springs
Hi Guys started fitting the new suspension from jimnybits, have the rear done ok and have read on here that there is no problem fitting the front springs I have done the pasenger side front it was a absolute cow to get in and the drivers side spring is longer i can not see any way of fitting this in, am i not doing something right, i am just jacking the vehicle up by the chassis so the axle will drop but it does not drop very far even with the shock removed, HHHHHHHHHHHHEEEEEEELLLLLPPPP, I had to use spring compressers on the passenger side and still had trouble getting it in, it is only a two inch lift, also on front shocks should you screw the thread on the top mount all the way down until it won`t go any further
- biggaz
22 Mar 2011 18:28 - 22 Mar 2011 18:30 #13814
by biggaz
Replied by biggaz on topic Re: Springs
The brake hoses will now be stopping the axle dropping, disconnect caliper and try should be loadsa room.
Thats why ots good to fit extended ones at the same time.
Last edit: 22 Mar 2011 18:30 by biggaz.
- little monster
22 Mar 2011 18:42 #13815
by little monster
Cheers will let you know tomorrow
- supergaz
22 Mar 2011 18:59 #13819
by supergaz
Replied by supergaz on topic Re: Springs
I managed to get in +3 springs and 1.5''spring spacers easily, the front o/s was the only one I needed to use clamps, the only thing that was holding the axle on was the bushes on the trailing arms.
- biggaz
22 Mar 2011 19:44 #13830
by biggaz
- Strek
23 Mar 2011 06:20 #13853
by Strek
Replied by Strek on topic Re: Springs
My 2" springs came on without compressor-clamps. But yes, it was a bit of hassle. You'll need muscles and a will. We also unscrewed the anti roll bar, but did not need to disconnect anything on the brakes to get them fixed. I changed the brakelines afterwards, but if you are to change them, do it first!
Time to create page: 0.166 seconds
