Alloys sizing and offset
- robp
15 Mar 2011 22:25 #13456
by robp
Alloys sizing and offset was created by robp
Would 8J x 15 et25 alloy wheels with standard 205/70 R15 fit on a standard Jimny without need for spacers? Would there be any issues with rubbing?
Thanks.
Thanks.
- biggaz
15 Mar 2011 22:56 - 15 Mar 2011 22:58 #13458
by biggaz
Replied by biggaz on topic Re: Alloys sizing and offset
Bugger, wrote some out then deleted it..
basically may catch (inside arch/susp etc) as its a pretty high offset, not sure really so add your dimensions of the original wheels and the new ones into the offset calculators online and see how much extra its going to sit in, then go measure while the original wheel is fitted to see if it will foul anything?
Is it the cheap alloys off alloywheels.com by any chance?
Oh and the 205's on the 8j are a little narrow, they will fit fine trust me i used to run over stretched tyres all day everyday but on a 4x4 its no good to go too narrow (any offroading?) 215+ would be better but i think 205's will get away with it.
failing that, buy and try... if its a failure just add some spacers
Last edit: 15 Mar 2011 22:58 by biggaz.
- robp
17 Mar 2011 11:51 #13506
by robp
Replied by robp on topic Re: Alloys sizing and offset
No, just quite a nice set on ebay: 180639352669
Have a look...
Have a look...
- biggaz
17 Mar 2011 13:47 #13514
by biggaz
Mate the et says 25 NEG, which will be negative 25 so will clear fine but stick out a bit.
Time to create page: 0.159 seconds
