Engine Will Not Start
- John_S_RAA
15 Mar 2011 20:05 #13437
by John_S_RAA
Engine Will Not Start was created by John_S_RAA
My “T†reg Jimny has been on SORN while I sort out a few issues after a lot of abuse thrown at it whilst taken part in various winch challenge events. When I went to start it recently, it would not fire. Checked the usual; petrol is ok, turns over but there is no spark. Fitted a known good ignition pack off of another Jimny still would not start. CHECK ENGINE light continually flashes. Disconnecting battery does not clear this.
Any ideas as to where I should look next would be appreciated.
Engine is G13BB
Engine is G13BB
15 Mar 2011 20:17 #13439
Replied by mlines on topic Re: Engine Will Not Start
Not much help but your not in the Thames Valley/Swindon area are you?
15 Mar 2011 20:29 #13441
by kirkynut
Replied by kirkynut on topic Re: Engine Will Not Start
You could really do with a diagnostic check on it. Can this not be done with a paperclip in certain pins of the OBD diagnostic port on these early ones Martin? It makes the engine check light flash according to the code does it not?
I can't remember to be sure.
Have you tried the spare key. I'm clutching at straws to be honest but have a niggling thought it could be the immobiliser system messing about. I don;t want to frighten you with that as I really don;t know if it could be the case but worth a try.
- John_S_RAA
15 Mar 2011 20:36 #13442
by John_S_RAA
Replied by John_S_RAA on topic Re: Engine Will Not Start
Have tried the spare key...immobiliser was what crossed my mind.
- John_S_RAA
15 Mar 2011 20:37 #13443
by John_S_RAA
Just outside Alton...you delivered some bearings to me on your way to Slab Common once upon a time.
- Brian.SMC
15 Mar 2011 21:36 #13448
by Brian.SMC
Replied by Brian.SMC on topic Re: Engine Will Not Start
Unplug the ecu for 5min see if it clears the fault code.
Time to create page: 0.168 seconds
