spacers
  • viciouspenguin
15 years 8 months ago #13363 by viciouspenguin
spacers was created by viciouspenguin
Should i fit wheel spacers or not?
whats the long term effects on wheel bearings and will i need to trim anymore bodywork?
  • gazert
15 years 8 months ago #13389 by gazert
Replied by gazert on topic Re: spacers
Had mine on a year and no adverse effects.
No body mods needed.
Makes it far better off road as it goes in the ruts made by our green oval friends! Watch out for extra deep ruts as u may beach yourself!
  • srcars
15 years 8 months ago - 15 years 8 months ago #13390 by srcars
Replied by srcars on topic Re: spacers
Can of worms :unsure:
Really down to personal experiance. I had a set on a Delica (2 ton vehicle) no problems at all and then we had one very nearly let go on the front of this whilst cornering.
The wheel was only held on by 1 extended nut. very scarey. In my opinion they will shorten the life of wheel bearings but no worse than larger wheels ect. Would I use them again ? If I couldnt find the right offset wheels yes.
Just make sure you follow the instructions and fit them properly :)
Last edit: 15 years 8 months ago by srcars.
  • biggaz
15 years 8 months ago #13391 by biggaz
Replied by biggaz on topic Re: spacers
do you have lower offset wheels? or standard ones?
  • mcjimny
15 years 8 months ago #13394 by mcjimny
Replied by mcjimny on topic Re: spacers
srcars wrote:
On a side note that is properly cool! I've tried looking at the pics on your site but they don't load.
  • viciouspenguin
15 years 8 months ago #13404 by viciouspenguin
Replied by viciouspenguin on topic Re: spacers
i'm more concerned with the wheels catchin on the bodywork. i used to have an SJ410 and when i fitted wheel spacers i had to remove some of the chassis (bumper mounts).
the wheels are already slightly offset but they have a wider width so it balances out, they dont realy protrude past the arch.
as for the photos not loading, umm its powered by a java script. it might be worth checking to see if you have active x plug ins enabled in internet exploiter or that you have the lastest version of java on your machine. failing that you can always right click on the thumbnail and select open link in new tab/window :)
Time to create page: 0.105 seconds
