Rear axle oil seal removal
- mcjimny
15 Sep 2009 17:52 #1267
by mcjimny
Rear axle oil seal removal was created by mcjimny
How the frigging hell do you get this out? I am trying to remove the right thing aren't i?
It has a metal outer facing me and a rubber ring behind with a series of holes in it.
Brute force and ignorance?
Muchos thanks in advance.....
15 Sep 2009 18:58 #1268
Replied by mlines on topic Re:Rear axle oil seal removal
The metal outer is the oil seal, the rubber ring behind it with the holes in is the oil seal protector. I use the "claw" part of a claw hammer. Gently insert it behine the metal outer, inbetween the seal and the protector behind it. Then "rotate" the claw and the seal should move.
- mcjimny
15 Sep 2009 19:04 #1269
by mcjimny
Replied by mcjimny on topic Re:Rear axle oil seal removal
Martin, thanks for the swift reply. For a while i thought i'd trashed soemthing i shouldn't.
I've ordered one of the bearing kits, is this what the generic seal replaces thats included?
15 Sep 2009 19:07 #1270
The generic seal replaces the metal covered seal. The ones I supply dont have the metal outer but it does not seem to make any difference on my car
- mcjimny
15 Sep 2009 19:15 #1271
by mcjimny
Thats brilliant. I've got it all in bits, ready to reassemble in time for this weekend.
Got all of it apart easy enough, the retaining ring and bearing race needed some serious grinding to get them to shift though. Still, got to play with my new grinder.
Thanks for the help.
Matt
Matt
Time to create page: 0.232 seconds
