Jimny 99 Rocker Cover Oil Leak
- bertbuckie
09 Mar 2011 18:45 #12912
by bertbuckie
Replied by bertbuckie on topic Re: Jimny 99 Rocker Cover Oil Leak
Well took her out today...... no leaks as yet
Fingers crossed I have fixed it with a little RTV and some cleaning until I have to buy a new gasket ( hopefully many many thousands of miles later
) Please Log in or Create an account to join the conversation.
- bigfoot
13 Apr 2011 20:33 #14994
by bigfoot
Replied by bigfoot on topic Re: Jimny 99 Rocker Cover Oil Leak
whats the recommended torq setting for the rockercover bolts??
also is there anywhere else at the rear of the head that can leak?i've got quite a bit of oil leaking in that area which is running onto the gearbox and exhaust, there appears to be a cover plate and a housing that has a sensor on it, can these leak oil or is it more likely to be the rear of the rocker cover gasket?
thanks
thanks
ifacade wrote: Overtightening the fixing bolts distorts the gasket, overcompresses it and causes it to leak as it hardens with age. Once they start to weep oil (they all do that sir!) the garage response is to nip them up a bit more, that works for a few hundred miles. Replacement is the only solution.
Got the same trouble on our little Corsa. I bought a new gasket once, but a spray of degreaser every now and again seems to do the trick.
Time to create page: 0.372 seconds
