Jimny 99 Rocker Cover Oil Leak
  • bertbuckie
06 Mar 2011 13:13 - 06 Mar 2011 13:17 #12666 by bertbuckie
Jimny 99 Rocker Cover Oil Leak was created by bertbuckie
Before I start I appologise for the small pictures and the frequency of which they are uploaded in individual posts. I am on GPRS internet via android wifi tethering.....no broadband..... not even a 3G signal :( - If mods want to join the posts to make it better please feel free :)
Well.... after yesterdays fiasco with a snapped brake caliper bolt I decided to interfere with a more technical part of my car today...... the rocker cover.
I noticed a while ago ( well someone pointed out to me at the 4x4 day at Memsie ) that I had a lot of oil on top of my gearbox :/ So I monitored oil levels and determined the engine oil was slowely dropping and it appeared to be comming from the rear of the rocker cover.
Bieng a tight scotsman I didnt buy a new gasket..... hell no! I might be able to make do with the one already there lol......time will tell I guess!
Heres what I did incase it works and anyone else has the same problem............
First..... looked at the engine a bit......
Last edit: 06 Mar 2011 13:17 by bertbuckie.
  • bertbuckie
06 Mar 2011 13:21 - 06 Mar 2011 13:29 #12667 by bertbuckie
Replied by bertbuckie on topic Re: Jimny 99 Rocker Cover Oil Leak
Well..... it appears I timeout trying to upload even one shrunk picture so no pics for 5 weeks unless I can email them ( which seems to work ) to someone else to post
Edit.... just checked.... 1400kbs so 1.4 megish.....stupid slow internet :(
Last edit: 06 Mar 2011 13:29 by bertbuckie.
06 Mar 2011 20:32 #12717 by mlines
  • bertbuckie
06 Mar 2011 20:48 #12718 by bertbuckie
Right.... as you can see in the pics martin kindly uploaded for me.....
oil leaked everywere :(
Took all rocker cover bolts out
took off pipes / plugs / wires
cleaned every gasket surface
cleaned gasket
used RTV silicon in gasket seat and on gasket flat edge ( didnt go mental with RTV..... too much would be bad I think )
Stuck it all back togeather again :)
Will wait untill tomorrow or the next day to ensure its set to trial it.....also need to clean all the old oil off to see if its still leaking :( - if it is I will buy a new rocker cover gasket lol..... this might be a cheap fix tho :)
  • bertbuckie
06 Mar 2011 20:53 #12719 by bertbuckie
Ohhhh..... and note the rocker cover gasket deformitiy..... strange and this is where most the oil was leaking from :(
06 Mar 2011 21:16 #12720 by facade
Overtightening the fixing bolts distorts the gasket, overcompresses it and causes it to leak as it hardens with age. Once they start to weep oil (they all do that sir!) the garage response is to nip them up a bit more, that works for a few hundred miles. Replacement is the only solution.
Got the same trouble on our little Corsa. I bought a new gasket once, but a spray of degreaser every now and again seems to do the trick.
