Compression for G13BB engine
- Littlebear
06 Mar 2011 10:36 #12643
by Littlebear
Compression for G13BB engine was created by Littlebear
Hey guys!
Very nice forum i found here,with good topics! keep up the goodwork!
I own a cabrio jimny with g13bb engine and i didn`t found anywhere the compression rate for this engine,i intend to install a small turbo,without intercooler:) does anyone have specs for this engine?
Thanks!
Thanks!
06 Mar 2011 12:15 #12655
Replied by mlines on topic Re: Compression for G13BB engine
- Littlebear
06 Mar 2011 14:31 #12674
by Littlebear
Replied by Littlebear on topic Re: Compression for G13BB engine
Thank you very much! After i`ve done some calculations i got 9:1 ratio,should be good for 10psi boost without changing rods and pistons.
- bertbuckie
06 Mar 2011 14:37 #12677
by bertbuckie
Replied by bertbuckie on topic Re: Compression for G13BB engine
If its not a stupid question..... why do you want to turbo a jimny?
Also are you turboing it off the exhaust or electricly? ( probably be easier to use a supercharger setup Id imagine ? )
Just curious
Bert
Just curious
Bert
06 Mar 2011 14:55 - 06 Mar 2011 14:56 #12678
by facade
Won't that push the pressure up to 340 psi? I would have thought that was a bit much with everything just standard, but I'm certainly no expert.
I do recall that people used to use much thicker head gaskets with turbo'd engines to limit the compression pressure.
Replied by facade on topic Re: Compression for G13BB engine
Littlebear wrote: Thank you very much! After i`ve done some calculations i got 9:1 ratio,should be good for 10psi boost without changing rods and pistons.
Last edit: 06 Mar 2011 14:56 by facade. Reason: oops! units
- Littlebear
07 Mar 2011 07:59 - 07 Mar 2011 08:02 #12745
by Littlebear
I want to turbocharge it because i need extra power to drive 31" wheels,body is heavier now with front,rear steel bumper and exterior rollcage and winch.
It`s easy to install a turbo,i have plenty of space under the bonnet,the only tricky thing will be the exhaust manifold,and maybe the stand-alone ecu if needed.I`ll keep you posted with pictures as soon as i will start turboing,right now they are working on the exterior rollcage:)
Regarding the pressure,will see in tests how much boost can it handle,and if not,forjed pistons and rods:D
Last edit: 07 Mar 2011 08:02 by Littlebear.
Time to create page: 0.168 seconds
