rear bushes of radius arm (blueprint): i need help
- renard38
04 Mar 2011 18:40 #12540
by renard38
Replied by renard38 on topic Re: rear bushes of radius arm (blueprint): i need help
no, all my bushes where in the correct place ( but ADK 88006 are to soft )
I've recived an email from camskill, and they said me, i must wait untill june for the front bushes :sick: :S
04 Mar 2011 21:45 #12552
by facade
Replied by facade on topic Re: rear bushes of radius arm (blueprint): i need help
You did fit the 4 axle end bushes with the slots lined up correctly, as the diagram in the manual, or Martin's guide?
The axle is supposed to roll around a little as the rubbers compress, with the handbrake on I can rock mine back and forwards, and see the pinion rise and fall. This initially worried me, but I applied rule #1 (If it ain't broke: don't fix it) and Rule #2 (Don't mess!) and saved a lot of time and money by not replacing any bushes.
If you want to stop the axle moving, fit solid polybushes.
I read somewhere about using the solid chassis end bush at the axle end, and that the front chassis bush is much firmer than the rear, but if you have to wait until June and are bothered by the flex go the polybush route.
- g187eev
04 Mar 2011 22:18 #12554
by g187eev
Replied by g187eev on topic Re: rear bushes of radius arm (blueprint): i need help
The bushes you have fitted are 90 degrees out...
RB
RB
- renard38
06 Mar 2011 08:24 #12637
by renard38
yes, i fit the 4 axle end bushes with the slots lined up correctly, as the diagram in the manual.
perhaps, i can buy the same bushes as blueprint ADK 88008 at rhinorays.co.uK or zanfi..
- renard38
10 Mar 2011 19:06 #13001
by renard38
hi,
i had no answer from rhinorays, and zanfi are too expensive, so i bought rear suzuki bushes.
There is a big difference between those two bushes: suzuki ones are more stronger, now it's not moving a lot
So an advice: dont buy blueprint ADK 88006 because they are too soft for the rear, you better put ADK 88008
A+
A+
