HD steering damper
  • Asbojimny
04 Sep 2009 18:48 #1242 by Asbojimny
HD steering damper was created by Asbojimny
Anyone know if there's any Heavy Duty steering dampers out there for sale.???
Running 30's the Jimny feels a bit,er........ twitchy. A kind of aqua plaining without the water!!! At low sppeds on rough A roads and at speed on Motorways,hope this might help resolve the problem.
Cheers.
06 Sep 2009 10:47 #1243 by kirkynut
Replied by kirkynut on topic Re:HD steering damper
Have a look at www.dgtuning.com/
  • Jamie
06 Sep 2009 14:40 #1247 by Jamie
Replied by Jamie on topic Re:HD steering damper
I have fitted a land rover discovery damper on mine really up to the job
drives a lot better.
Total cost was £23.50 .... Bargain
Jamie
  • Asbojimny
06 Sep 2009 15:50 #1248 by Asbojimny
Replied by Asbojimny on topic Re:HD steering damper
Jamie
Any info or pics on how you fitted it Jamie?
Thanks for the link,found the damper kit but no price,will send e mail,cheers
  • Jamie
06 Sep 2009 16:56 - 06 Sep 2009 17:03 #1249 by Jamie
How's this for you.............
1st i bought a bracket from Dave at www.llama4x4.co.uk for the bargain cost
of £5.00
Then i ordered a Discovery series 1 steering damper from Tamar 4x4
stores.ebay.co.uk/tamar-4x4-store
Cost £17.48 delivered
I found a peice of 6mm angle iron in our scrap bin perfect for the job
I then drilled a 16mm hole this is the correct size for the damper bushes
So now we have all the parts we'll get started
I cut off this recovery eye from the near side front chassis rail
This was left and all was ground down nice and flat
Meanwhile the bracket from llama was fastened to the steering arm close to
the pitman arm
After a few trial fittings the bracket was welded in place where the recovery
eye was
The damper was the all offered up to check all measurements were correct the masking tape shows
1. fully closed
2. Centred position 103mm
Then its a matter of cleaning up and fitting the damper ensuring everything
is nice and tight and then enjoy how your Jimny drives
Big thanks to chrisuki for all the help and cups of tea
Last edit: 06 Sep 2009 17:03 by Jamie.
  • Asbojimny
13 Sep 2009 14:06 - 14 Sep 2009 15:31 #1263 by Asbojimny
Thanks for that Jamie,top write up. Much appreciated,will need to get onto llama at start of week. Just got wheels aligned,makes a difference. The wheels were toe'd inwards so all zero'd out now.
Llama's out of stock of brackets,i'll just make one up,ordered the Disco steering damper,hopefully have it fitted for end of week :)
Last edit: 14 Sep 2009 15:31 by Asbojimny.
Time to create page: 0.335 seconds
