what engines fit
  • vitara_mad
01 Mar 2011 08:15 #12332 by vitara_mad
what engines fit was created by vitara_mad
is there any other engines that will be a straight swap into a sohc jimny as we finding it difficult or very expensive to find a jimny engine
or a engine that will at least fit the gearbox & require wiring up & new mounts making
basicly any info you can give on fitting any engine into the jimny would be great
thanks
  • mcjimny
01 Mar 2011 08:22 #12333 by mcjimny
Replied by mcjimny on topic Re: what engines fit
Baleno 1.6 fits, martin sells the adapters www.bigjimny.com/store/index.php/jimny-p...aptor-kit/p_120.html
Peugeot 1.7 diesels were popular in sj,s but i've not seen many in Jimnys of course though anything can be made to fit if you have the skills at your disposal.
  • distantcamera
01 Mar 2011 14:51 #12349 by distantcamera
Replied by distantcamera on topic Re: what engines fit
mcjimny wrote: Baleno 1.6 fits, martin sells the adapters www.bigjimny.com/store/index.php/jimny-p...aptor-kit/p_120.html
There's a Baleno 1.6 on ebay at the moment, £250 with free delivery. 230580431254
  • trextr7monkey
01 Mar 2011 16:10 #12351 by trextr7monkey
Replied by trextr7monkey on topic Re: what engines fit
A bloke I know bought an SJ fited with a 2 litre pinto which must have given it a bit of ooomph, not sure what was involved in mating it up to the 4WD though
  • srcars
01 Mar 2011 16:29 #12353 by srcars
Replied by srcars on topic Re: what engines fit
Why not go retro and fit a 1300 SJ engine, Just make sure you change the carb ;)
  • bryandenham
01 Mar 2011 17:27 #12356 by bryandenham
Replied by bryandenham on topic Re: what engines fit
i believe the old 1.6 Vitara fits. the top two bolts go straight in and new holes needed for the bottom two.
The carb engine is best, no electronic probs. Maybe a slight bit of work to fit the starter and alter the engine mounts.
Question, will the single cam Jimny electronics suit the Baleno engine?
Bryan D
Time to create page: 0.101 seconds
