Waterproofing - axles gearbox etc
  • ronm
24 Aug 2008 17:58 #123 by ronm
Waterproofing - axles gearbox etc was created by ronm
Assumed Jimny was waterproofed but now discover need to fit raised breathers to diffs.Do I need any more?
25 Aug 2008 08:36 #127 by mlines
The diff housings and the transfer box have breathers, the gearbox doesn't (unless you have a European Diesel).
Prise the caps off the breathers and extend them upwards.
One of the propshafts has the only greasing point on the car so push grease through this on a regular basis and keep the radiator spotless as they are quick to overheat if the radiator is blocked in any way. If yours has a radiator cowl fitted make sure it is clean at the bottom rear after wading.
  • ronm
25 Aug 2008 09:53 #129 by ronm
Replied by ronm on topic Re:Waterproofing - axles gearbox etc
Many thanks will sort this week.
Time to create page: 0.079 seconds
