Rear lights
  • JimnyApple
26 Feb 2011 20:50 #12230 by JimnyApple
Rear lights was created by JimnyApple
Has anybody wired up the rear body lights so that they work with the bumper lights?
Am I right in thinking that the LHD European models have their body lights working from the factory?
I
  • Monkey
26 Feb 2011 22:37 #12241 by Monkey
Replied by Monkey on topic Re: Rear lights
Are talking about the lights on the corners near the rear window?
  • benson
28 Feb 2011 06:56 #12290 by benson
Replied by benson on topic Re: Rear lights
Fitting double stop and tail lights are no prob,you would need a bit of experience with basic wiring second hand stop and tail bulb holders,wire,hole saw and a current tester.
-The top lights are blanket one side so you need to bore holes for the SH bulb holders to fit the other
Is for the fog lamp which you would have to remove for the stop and tail holder I held these with hot glue which can be snapped if you need to change a bulb
- getting your live and earth for your stop tail can be got using a current tester on the wiring loom into the bottom lamps in which you can solider the wires to join then
-it just takes time but looks good when it's done
  • JimnyApple
28 Feb 2011 09:49 #12296 by JimnyApple
Replied by JimnyApple on topic Re: Rear lights
Cool thanks Benson, will have a look at doing that i think. It seems a waste not to
have them working. It looks good too on the you tube videos when they are working.
  • bluejimny
28 Feb 2011 10:27 - 28 Feb 2011 10:29 #12297 by bluejimny
Replied by bluejimny on topic Re: Rear lights
yes i did it on my old one, basic wiring and your done!
Last edit: 28 Feb 2011 10:29 by bluejimny.
  • MRocha
28 Feb 2011 10:34 #12298 by MRocha
Replied by MRocha on topic Re: Rear lights
...look my ...
[IMG
Uploaded with ImageShack.us
Time to create page: 0.377 seconds
