Bleeding ABS Brakes
22 Feb 2011 12:11 #12002
by Obarno
Bleeding ABS Brakes was created by Obarno
No I'm not having a moan about the braking system! Is there a technique to bleeding Jimny abs brakes or do they bleed like ordinary ones? Do you need the engine running to work the abs pump and is it ecu controlled? I know our friends (!) with the green oval have lots of bleeding problems with their abs systems.
- biggaz
22 Feb 2011 12:13 #12003
by biggaz
Replied by biggaz on topic Re: Bleeding ABS Brakes
When i fitted my hoses i bled them as normal?
22 Feb 2011 14:40 #12007
by Obarno
Replied by Obarno on topic Re: Bleeding ABS Brakes
Thanks biggaz thats great.
- biggaz
22 Feb 2011 17:51 #12015
by biggaz
Sorry should have said, they were fine afterwards...
Started furthest away from master cylinder etc as you do.
- Smoggy
22 Feb 2011 17:55 #12017
by Smoggy
Replied by Smoggy on topic Re: Bleeding ABS Brakes
Mind from what i saw on Sunday im surprised your not bleeding mud from your master cylinder gaz! lol
22 Feb 2011 18:38 #12022
by facade
Replied by facade on topic Re: Bleeding ABS Brakes
dont know if the abs type has the compensator valve above the rear axle, but there is a nipple on this that bleeds the front brakes, that has to be bled first.
