4wd vacum hose set up
- Asbojimny
22 Aug 2008 07:48 - 22 Aug 2008 07:49 #118
by Asbojimny
4wd vacum hose set up was created by Asbojimny
As mentioned before. Ripped out all the vacum hoses the other weekend from underneath Asbo. Including the metal pipes that run along radius arms. Does anyone ( martin :laugh: ) have a diagram of where everything should be. Looked through the jimny file i downloaded but cant find anything:(
ps. Going off roadin tmrw:ohmy:
Cheers.
Cheers.
Last edit: 22 Aug 2008 07:49 by Asbojimny.
22 Aug 2008 09:29 - 22 Aug 2008 09:32 #120
Replied by mlines on topic Re:4wd vacum hose set up
The wires that run along the radius arms are for the ABS system as far as I know. The vacuum tubes come along the axles. This is the best overall diagram I have.
Here is a higher resolution version attached
Last edit: 22 Aug 2008 09:32 by mlines.
22 Aug 2008 09:47 - 22 Aug 2008 09:49 #121
Ok - failed to attach - here is another go
Attachment vacuum.doc not found
Last edit: 22 Aug 2008 09:49 by mlines.
- Asbojimny
22 Aug 2008 11:33 #122
by Asbojimny
Replied by Asbojimny on topic Re:4wd vacum hose set up
Cheers for that. Knew you'd have it. Think it shows the hose/pipe running along the radius arm just before it heads up the way. We're going to re route it so they keep out the way.
Time to create page: 0.178 seconds
