Samurai and Jimny Diffs
18 Feb 2011 14:25 #11731 by Obarno
Does anyone know if a Sammi rear diff will fit a Jimny? Just looking at different axle ratios trying to decide what to do!
  • vitara_mad
18 Feb 2011 14:43 #11732 by vitara_mad
Replied by vitara_mad on topic Re: Samurai and Jimny Diffs
i know someone who has a samurai with a jimny rear axle & it has a samurai diff in it so the rear will fit i would like to know if a front samurai diff fits jimny front axel then could poss fit 5.1 ring & pinion from a vit
  • panosd
18 Feb 2011 14:54 #11733 by panosd
Replied by panosd on topic Re: Samurai and Jimny Diffs
If you want to change ring and pinions of the diff to make it lower to fit bigger tires,
you can put the diffs from the jimny japan spec(left side driver) with ratio 11/45.
If your jimny is from 99 to 03 its perfect.(ratio 11/43)
Also you can fit the diffs from the vvt. It gives you a -12%, -15% lower ratio.
If you want just to replace it because is damadged, it depends on the model you have.
In some jimny's the rear arb from the sami fits.
18 Feb 2011 15:18 #11735 by Obarno
Replied by Obarno on topic Re: Samurai and Jimny Diffs
Hi Vitara Mad - a Sammi front diff won't fit a Jimny as the Jimny has a high pinion diff. Interesting that a Sammi rear will fit a Jimny rear as I am trying to sort out ratios for VVT with rocklobster that is very low geared.
You can buy ring and pinions from these people in France
www.erm4x4.fr/Jimny/Ponts-transmisions-jimny.html
Thanks Panosd - more foor for thought!
  • panosd
18 Feb 2011 17:56 #11750 by panosd
Thats why we are here. To help its other finding solutions.
What about the link you gave above?
I will send you a pm for some details.
