Oil leak
- myers647
14 Feb 2011 20:23 - 14 Feb 2011 20:26 #11534
by myers647
Hi there,
right I'm not no mechanic but il have a go. Iv had an oil leak for about a month which I thought was the sump so I took it off cleaned it up and re-sealed it back on but no luck it's still leaking . I have now narrowed it down to the engine / gearbox seal, has anyone ever heard of oil leaking from here before and is it easy to change or does the gearbox have to be dropped out.
If anyone could help this would be appreciated.
Thanks
James
Oil leak was created by myers647
Thanks
James
Last edit: 14 Feb 2011 20:26 by myers647.
14 Feb 2011 21:12 #11544
by facade
Replied by facade on topic Re: Oil leak
Is it gear oil? very smelly and you wont wash the smell off.
If it is engine oil then most likely the rear crankshaft oil seal is leaking.
The gearbox has to be moved back, the clutch removed, then the flywheel comes off, and the seal can be changed.
If it is gear oil then the front gearbox oil seal has to be changed: remove the gearbox.
If it is only a few drips, buy a cheap baking tray, weight it with gravel and position over the mark on your drive to collect the drips.
Time to create page: 0.147 seconds
