Hub problems
  • tunguska
29 Sep 2009 12:15 #1328 by tunguska
Replied by tunguska on topic Re:Hub problems
hi guys. I'm driving an '06 AT model with push button 4WD. The local workshop installed the AVM manual hubs but we ran into some problems. It goes into 4WD OK but it can't disengage from 4WD into 2WD even when the hub is switched to 4x2 mode. In the end, we had to remove the AVM hubs and reinstall the stock vacuum hubs. Is there a way to make the AVM hubs work with a push-button 4WD system? If so, how do I go about doing it? Detailed instructions / pictures would be very much appreciated. Thank you!
Time to create page: 0.068 seconds
