CB Question
- Pete E
07 Feb 2011 21:30 - 07 Feb 2011 21:32 #11172
by Pete E
CB Question was created by Pete E
Just fitted a basic Midland 98 Plus along with a mini orbitor antenna...
The orbitor was originally a Mag mount, but I've removed the main antenna from the magnetic base and now have it fitted on a mount on the roof rail just above the drivers door..
SWR is at 1.6 on Ch 1, 1.5 on Ch 40 and 1.3 on Ch 19 so I assume everything is healthy enough..
Now the question. To get the SWR down to those levels I had to adjust the left whip out of the coil by about 2"...
As antenna is painted, it looks a bit naf but more importantly, the tiny grub screw that holds the whip into the coil is only just bitting the bottom of the whip and I don't think will be secure.
What are my options for inceasing the electrical length of the antenna?
If I fit a quick release fitting between the mount and the bottom of the antenna, will that be added electrical length? I assume it will be, but not 100% certain as it would below the coil/spring...
Also, do the Thunder Pole quick release fittings hold up to offroad use?
Regrads,
Peter
Regrads,
Peter
Last edit: 07 Feb 2011 21:32 by Pete E.
08 Feb 2011 06:09 #11177
by kirkynut
Replied by kirkynut on topic Re: CB Question
The grub screw will do just fine and taking 2" off is no probs. With those readings leave it alone!
- ooky_123
09 Feb 2011 10:12 #11222
by ooky_123
Replied by ooky_123 on topic Re: CB Question
if your in doubt, pout some threadlock of superglue in the grubscrew threads.
My SWR 's 1.2 - 1.4 across the range. I use a mag mount, so I know if this was replaced with a propper bodymount, it would be well below 1.
I get about 10 - 20 miles range in open country and 5 - 6 miles in a builtup area
- biggaz
09 Feb 2011 10:44 #11225
by biggaz
Replied by biggaz on topic Re: CB Question
i bought a small springer for my mag mount on roof, the guy in the CB shop says dont need to swr it... i dont have any experience of CB's so kinda believed him but was unsure as i though all aerials should be tuned?
- ooky_123
09 Feb 2011 11:16 #11228
by ooky_123
Yes all ariels "should" be tuned as a poorly tuned ariel will fry the output stage of your CB (think Feedback).
However these days, most ariels are preset to a nominal setting that will, on average be suitable for just Plug & Go.
Also, I guess most people will use pre-made lengths of coax too.
If you are customising an install with long lengths of cable / soldering your own PL-259 plugs etc, these factors will affect the output resistance of your "rig" .. and hence then it may be necessary to adjust your ariels tuned length to a more optimum configuration.
Generally though, factory defaults on standard equipment "should" be fine for most people
As a precaution, I would check the SWR of the setup if you have access to someone with an SWR Meter
- Pete E
09 Feb 2011 18:47 - 09 Feb 2011 18:48 #11256
by Pete E
Mine was supposedly pre adjusted as well and the SWR 1:3 on Chl 40 when I first fitted it!
What part of the country are you? If you're with in a reasonable drive, I'd be happy to pop over with the SWR meter and give it a go..
Replied by Pete E on topic Re: CB Question
biggaz wrote: i bought a small springer for my mag mount on roof, the guy in the CB shop says dont need to swr it... i dont have any experience of CB's so kinda believed him but was unsure as i though all aerials should be tuned?
Last edit: 09 Feb 2011 18:48 by Pete E.
Time to create page: 0.162 seconds
