gear oil leaking again. grrrr!
06 May 2013 14:28 #70142 by gilburton
You're not the only one having problems with a later Jimny.
Initially I had the seal replaced. It leaked again. I then had it replaced again but also had a new propshaft fitted at the same time.
That I hoped would be it but again I am getting the familiar smell of hot oil on the exhaust although it's not as bad as the first seal. Not had a chance to have a look yet but will later this week!
I've just had it on the motorway at higher speeds than it normally does locally for the first time so I'm keeping my fingers crossed it's just excess oil coming out the breather??
Just to add it's only done 36K and is 2008.
Unfortunately it's 3rd hand and is well out of warranty although the dealer just charged for the prop not labour.
If it has gone again I think it will be an ebay job
What is it with these later boxes?? I got thousands of miles out of my old Jimny and any rear wheel drive cars I've had in the past have never given me any problems like this.
Someone must know?? The Suzuki dealer has said he has replaced a few so is Suzuki keeping quiet??
The seal is the same as the older models so it can't be that and the dealer checked for any play on the output shaft but was ok? :(
cgauer can you illustrate or take a pic of your solution??
I started off high and worked my way down ever since :-)
  • Dorfl
07 May 2013 09:45 #70192 by Dorfl
Replied by Dorfl on topic gear oil leaking again. grrrr!
I've taken to treating the leak from my '08 as an extra level of rust protection :S (tried new seals, and on the 3rd transfer case with new seals etc.) i am thinking maybe the intermediate shaft is not quite true and deflecting the seal at speed? in the interim I have to clean the drive more regularly and try to convince people the cars not really a Land rover :evil:
  • cgauer
07 May 2013 16:51 #70214 by cgauer
Replied by cgauer on topic gear oil leaking again. grrrr!
Look what I've found:
And yes, I'm in the range of the affected ones!
Here is the Bulletin:
Issue No:Q-SN-006-R1
Subject: Oil leak
Jimny older than vin: JSAFJB43V00453307
This bulletin is to inform you of the modification of Propeller Shaft No.1 For SN413.
The customer may complain of an oil leak from the cap part of the sliding yoke. This is due to the insufficient performance of the sealing adhesive used on the cap during quick acceleration.
If you encounter this please take your Jimny to your dealer.
Source: auszookers.com/forum/viewtopic.php?f=5&t=39199&view=next
  • cgauer
28 May 2013 02:44 #71942 by cgauer
Replied by cgauer on topic Done!
Little update.
Today Suzuki Brazil replaced my prop-shaft (gearbox <-> transfer case) at no cost. It is a 2009 Jimny VVT manual and the warranty was over...
The newer prop features a shallower plug over the yoke/spline cup.
They had a total of 5 cars showing up for the job.
The job takes 45 minutes. Drain the gearbox oil, open the middle exhaust linkage (otherwise is impossible to remove the prop), unbolt it and of it goes.
Over the pictures, the older one featuring my epoxy temporary fix, actually it was holding perfectly well...
Pictures attached.
Best
Clemente
  • JivingDaddy
28 May 2013 05:54 #71944 by JivingDaddy
Replied by JivingDaddy on topic Done!
A solution at last. Congratulations. :)
28 May 2013 12:19 #71959 by Basketcase
Replied by Basketcase on topic Done!
Oh joy so the new gearbox I had to swap myself should have been covered here grrrr ill have to ask in work if this is true lol
Time to create page: 0.187 seconds
