gear oil leaking again. grrrr!
- g4vcn
05 Feb 2011 14:01 #11006
by g4vcn
gear oil leaking again. grrrr! was created by g4vcn
As you know i had oil lealing from where prop goes indo gearbox. A few weeks back now i replaced the oil seal and now it is leaking again. Is it possible for oil to leak through the u joint as i have a new seal in the box and the u joint has oil all over it. the collar type part on the shaft seems to be dry.
any help please.
gav
any help please.
gav
- vitara_mad
05 Feb 2011 15:51 #11014
by vitara_mad
Replied by vitara_mad on topic Re: gear oil leaking again. grrrr!
is there any play in the bearing on the output shaft ???
- g4vcn
05 Feb 2011 19:24 #11044
by g4vcn
Replied by g4vcn on topic Re: gear oil leaking again. grrrr!
what part is the output bearing?
gav
gav
- biggaz
05 Feb 2011 19:58 #11051
by biggaz
Replied by biggaz on topic Re: gear oil leaking again. grrrr!
Isnt this the new jimny, id seriously be taking this back under warrenty! SOD the offroad/mods at least get them to pay some of it!
- g4vcn
05 Feb 2011 20:21 #11055
by g4vcn
yeh its the 09 plate. once i got the body lift off its back to standard. so i think ill just be going back to suzuki. its soon to be going up for sale but wont sell untill i know its a running how it should.
gav
gav
- cgauer
05 May 2013 21:56 #70115
by cgauer
Replied by cgauer on topic gear oil leaking again. grrrr!
Same Issue! :blush:
I thought it was the rear gearbox seal.. But it wasn't. The collar was 100% clean and dry.
The culprit was the u-join itself. The end of it had a plate that seals the bottom part of the sliding spline (oil fed). Cleaned and filled it with high strength epoxy resin (the outer part of it).
30 min in-place job.
It is a 2009 VVT manual.
Time to create page: 0.168 seconds
