Drivers doorlock/central locking
  • garymmorgan
31 Jan 2011 21:42 #10730 by garymmorgan
Drivers doorlock/central locking was created by garymmorgan
Hi,i`m having a problem with my drivers doorlock sticking-i have to turn the key both left & right in order to open/close the door....any suggestions please
Many Thanks
Gary
01 Feb 2011 05:45 #10737 by facade
Take the door panel off, and see what has gone wrong with the linkages and lock.
Try lubricating the lock from the outside first.
  • zukhunter
01 Feb 2011 07:03 - 01 Feb 2011 07:04 #10741 by zukhunter
Replied by zukhunter on topic Re: Drivers doorlock/central locking
my jimny the same i ve tried wd40 still the same problem
its like the barrels is worn .... damm annoying
waiting on breaking the key sometimes
Last edit: 01 Feb 2011 07:04 by zukhunter.
  • darthloachie
01 Feb 2011 07:34 #10742 by darthloachie
Replied by darthloachie on topic Re: Drivers doorlock/central locking
Ours is the same
It unlocks better if we don't put the key all the way in!
You just have to j-j-j-j-j-jiggle it a bit Granville :whistle:
  • Keefe
01 Feb 2011 07:49 - 01 Feb 2011 07:50 #10745 by Keefe
Replied by Keefe on topic Re: Drivers doorlock/central locking
No eBay APP ID and/or Cert ID defined in Kunena configurationTry spraying in some graphite dust in, much better than oil.
You'll laugh but a 'know it all' Locksmith that we used to use at work, when I asked him for some, said there was no such thing as it or graphite grease.
Graphite grease is excellent on Bowden wire cables, throttle, clutch, etc etc.
I've 4 or 5 tubes of it in my shed, any door locks, padlocks etc that start playing up, one 'PUFF' and they're sorted.
Keith :)
Last edit: 01 Feb 2011 07:50 by Keefe. Reason: ebay link
  • ooky_123
01 Feb 2011 22:09 #10789 by ooky_123
Replied by ooky_123 on topic Re: Drivers doorlock/central locking
Well it must be Karma ... Drivers side door lock just started showing same symptoms as has been described above.
I filled the lock with some selenium lube and if you don't put the key all the way in it will sometimes work.
I intend to try and swap the door lock with the passenger one
Time to create page: 0.172 seconds
