cb's.... where to mount.
  • andyw
18 Jan 2011 14:08 - 18 Jan 2011 14:09 #9923 by andyw
Replied by andyw on topic Re: cb's.... where to mount.
Thanks Martin,
I used ali, because I had it lol, but as long as you shape it to the headlining should be fine, if you take the light off you,ll see theres two screws, and a big hole in the lamp base.
I just made the hole in the metal about the same size and drilled two hols to suit the two in the lamp base. I found two bolts the same thread and cut them down so they did'nt hit the roof.
It's been up there for a few years with no probs, powered straight from the batt with inline fuse, in the bulkhead via the gromit, then up the side of the winscreen pillar hidden behind the trim. I use a mag mount twig and have been happy with it .
hope that helps
Andy
Last edit: 18 Jan 2011 14:09 by andyw.
18 Jan 2011 16:22 #9927 by Johnniehec
At the risk of showing my age, do you still need a licence for a CB?:blush:
  • Keefe
18 Jan 2011 17:20 #9928 by Keefe
Replied by Keefe on topic Re: cb's.... where to mount.
Johnniehec wrote: At the risk of showing my age, do you still need a licence for a CB?:blush:
No you don't.
Great place to mount one as well, in the 'roof space'.
That's where mine's going to go.
K :)
  • vitara_mad
18 Jan 2011 17:34 #9929 by vitara_mad
Replied by vitara_mad on topic Re: cb's.... where to mount.
mine is in the same place as jonplace but i also like that roof mounted idea
  • biggaz
18 Jan 2011 18:01 #9931 by biggaz
Replied by biggaz on topic Re: cb's.... where to mount.
Yeh it is a nice idea, thanks again!
Got a CB now so just need to get a bracket sorted to mount it, came with a mag mount and home power supply which i'll not use.
Will be wiring straight to car not via cig lighter plug i think.
Its a midland 80 channel
Attachment IMAG0158.jpg not found
Never been used hardly so spot on.
  • paulnb57
18 Jan 2011 19:10 #9943 by paulnb57
Replied by paulnb57 on topic Re: cb's.... where to mount.
I use one of these
Usable inside or outside the truck, esp good when winching, usually run from a 12v ciggy power supply cos it takes 10 pencell batteries!! No screw holes or bracketry.
Range is OK in an off road convoy............all I need.....
Cost a fiver off ebygumbay
Paul
Time to create page: 0.257 seconds
