jackin points and tools
  • bertbuckie
19 Jan 2011 20:44 #10008 by bertbuckie
Replied by bertbuckie on topic Re: jackin points and tools
i use blocks under a trolley jack under the trail arms...... then axel stands under the chassis :)
hope this helps :)
18 Sep 2023 17:29 - 18 Sep 2023 17:38 #250877 by Buzz
Replied by Buzz on topic Re: jackin points and tools
Reviving an old thread but:
I'm going to replace a broken front spring on a Jimny later this week so planned on lifting front up and putting jack stands on frame rails somewhere then lowering the front axle down to get the spring out.
Ideally I'd like to lift it up level and put both left and right stands in together rather than do it one side at a time - just prefer not to be jacking the car out of level on one stand already.
Do you think it's ok to jack off the front axle in the middle next to the diff on the weld? Just concerned about weight of engine.
Anybody do this or you think I'm better lifting it one side at a time?
Cheers
Buzz
PS workshop manual says "put jack against the centre portion of the front axle housing" but the picture shows the jack on the diff which is obviously not the centre.
Last edit: 18 Sep 2023 17:38 by Buzz.
18 Sep 2023 17:51 #250879 by jackonlyjack
I use 2 trolley Jack's under radius arms
Also now I have a different front chassis cross member so can use a hi-lift/farm Jack in middle
Just go up in incremental with the stands to avoid to much lean
I find it easier to use a ratchet strap to get panhard rod back into position
The following user(s) said Thank You: Buzz
19 Sep 2023 09:41 #250888 by yakuza
Replied by yakuza on topic Re: jackin points and tools
I allways jack it up under the axles. Under the diff in the rear and at the side of the diff on the weld in the front. Using rubber on the jack to avoid it slipping, and never go under there without axle stands under axles or chassi.
For the front axle removal or service i think to place it only on the rails aft of the radius arms, if they have to come off, is bit too far back for my liking so usually secure it with an extra axle stand in the front somerwheere before daring to go under it. Mine has no added weight and what works for me, may not work for you so allways take due care and please use my hints at your own discretion and fitting for your own jack and stands.
20 Sep 2023 06:16 #250907 by Busta
Replied by Busta on topic Re: jackin points and tools
The engine weighs no more than an average man. The axle can take the weight just fine.
20 Sep 2023 13:02 #250912 by Buzz
Thanks for the replies all.
I did the job today (before reading recent replies - duh) so jacked it under the front diff. Obviously lifted on the skew but just jacked it high enough to get stands under frame rails both sides behind trailing arms and was careful lowering onto them.
I agree that's a bit far back for the stands but front wheels were just off the ground with jacks set quite high, so all good.
Time to create page: 0.217 seconds
