jackin points and tools
  • supergaz
16 Jan 2011 10:41 #9748 by supergaz
Replied by supergaz on topic Re: jackin points and tools
If only i could use axle stands on the axles, i'm planning on dropping them to replace my springs next!
  • Smoggy
16 Jan 2011 12:05 #9752 by Smoggy
Replied by Smoggy on topic Re: jackin points and tools
Halfords 2.25tonne black quicklift jack great value at the moment reduced from 80 quid to 34.99. Good lift height too!
17 Jan 2011 07:51 #9850 by kirkynut
Smoggy wrote: Halfords 2.25tonne black quicklift jack great value at the moment reduced from 80 quid to 34.99. Good lift height too!
That's the one. Snap it up now!
I think I had to jack it up on the chassis on one side, remove that wheel, lower the chassis onto an axle stand and repeat the other side.
Otherwise it sits chassis on axle stands with wheels still on the ground so you can't get them off or lower the axle enough to get the springs out.
  • Gromit
19 Jan 2011 19:15 #10000 by Gromit
Replied by Gromit on topic Re: jackin points and tools
For jacking up when out laning I use the standard jack and carry a 4"x4" block of wood to put it on !!!
  • biggaz
19 Jan 2011 19:55 #10003 by biggaz
Replied by biggaz on topic Re: jackin points and tools
Thats the one i mentioned, bought it! Decent height aswell!
19 Jan 2011 19:56 - 19 Jan 2011 19:57 #10004 by facade
Replied by facade on topic Re: jackin points and tools
Jack the axle up as high as you can, then block the chassis up, remove wheels, lower axle and remove, unless I misunderstand what you are trying to do
Last edit: 19 Jan 2011 19:57 by facade.
Time to create page: 0.468 seconds
