Jimny service help
- bertbuckie
09 Jan 2011 19:16 #9208
by bertbuckie
Jimny service help was created by bertbuckie
Right, after sifting through the service history I found I am due a timing belt change..... I am going to attempt this myself after aquiring a how 2 ( never done one before but looks straight forward enough - drain antifreeze, belts off, pully off, timing belt cover off, tensioner and belt out, make sure everythings lined up + not rotation more than 90 degrees, new belt on with no slack on drive side....reverse the rest )
I also plan to change the engine oil - 10w30 fully synth, air filter, oil filter, plugs ( just ngk's not iridiums )
Checked bearings, brakes, plan to check clutch cable and check underneith, plate the dodgy bits under bonnet/boot etc
Is there anything else I should consider? Especially with regard to diffs and gearbox etc?
Any advice ( as long as its good advice ) is very appreciated - especially an official service interval for individual componants
Bert
Bert
- mcjimny
09 Jan 2011 19:34 #9213
by mcjimny
Replied by mcjimny on topic Re: Jimny service help
If you're not sure when it was last replaced it may be worth dropping the diff oil too.
I'd not bother paying the extra for fully synth either, semi synth should be fine, I'm reasonably sure its 10w40 too unless the dohc ones use different oil.
- bertbuckie
09 Jan 2011 19:40 #9215
by bertbuckie
Replied by bertbuckie on topic Re: Jimny service help
Is it easy to do the diff oil? Any chance of a quick breakdown ( ive never done diff oil before but am mechy minded )
I got the oil 10w30 from martins info on oil here www.bigjimny.com/index.php?option=com_co...nformation&Itemid=63
- biggaz
09 Jan 2011 20:16 - 09 Jan 2011 20:18 #9219
by biggaz
Replied by biggaz on topic Re: Jimny service help
Diff oil is easy, davet talked to me about it but after changing transfer oil yesterday realised its daft not too.
Filler plug clearly visable on top half of both diffs, drain plug obviously nearer bottom.
Fill till it comes out of the filler, around a litre. Bit plumbers tape i used on the threads, nip up...jobs a gudden.
Ive just got one of them oil suction things from machine mart to re-fill.. makes it a bit easier.
Diff oil
80/90
Transfer oil
75/90
Diff oil
80/90
Transfer oil
75/90
Last edit: 09 Jan 2011 20:18 by biggaz.
- bertbuckie
09 Jan 2011 20:25 #9222
by bertbuckie
Cheers biggaz, this suction thing.... just a little oil pump ? I used to use them for silicone oil on downhole tools if it is
- biggaz
09 Jan 2011 20:34 #9226
by biggaz
www.machinemart.co.uk/shop/product/detai...l-transfer-equipment
made doing the transfer real easy, someone pointed me to it on my thread about my leak
Time to create page: 0.095 seconds
