hiii :)
  • bertbuckie
02 Jan 2011 08:25 #8630 by bertbuckie
Replied by bertbuckie on topic Re: hiii :)
is that a spring lift tho or a body lift a18suf? also got any pics and did you use shock relocators?
  • Adamski
02 Jan 2011 09:38 #8633 by Adamski
Replied by Adamski on topic Re: hiii :)
bertbuckie wrote: is that a spring lift tho or a body lift a18suf? also got any pics and did you use shock relocators?
She has a spring lift and shock relocators are required to give the shocks an extra inch of length.
02 Jan 2011 09:40 #8634 by mlines
Replied by mlines on topic Re: hiii :)
Body lifts are straight forward but you do get what you pay for.
The cheaper Ebay ones are simply polythene bushes and long bolts. Not only that but the longer bolts do not fit the Suzuki threads so you drill out the old ones and push the new bolts through, not very tidy. The more expensive kits have the proper threads so they fit the original Suzuki fittings.
Three areas need consideration for a body lift:
1. Steering spacer - the steering column may need a small extension in the joint.
2. Brake union - the brake union may be tight, the bodge trick is to leave it un-bolted in mid air.
3. Bumpers - you can get an ugly gap between the bumpers and the body. You need to consider moving the bumpers up.
Having said that they can be a cheap way forward. I have one kit available in the store which was a sample product, its the Bits$Vits body lift kit.
store.bigjimny.com/index.php?act=viewProd&productId=119
02 Jan 2011 09:44 #8635 by mlines
I can also do:
1 x Front Shock Absorber extensions (Suzuki Shocks ONLY)
1 x Rear Shock Absorber extensions
1 x Spring Spacers
for £140 plus delivery.
  • Adamski
02 Jan 2011 09:54 #8636 by Adamski
Is there any problem with using 2" spring spacers and a 3" sus lift at the same time to give a 5" lift?
  • vitara_mad
02 Jan 2011 11:18 #8637 by vitara_mad
Replied by vitara_mad on topic Re: hiii :)
Adamski wrote: Is there any problem with using 2" spring spacers and a 3" sus lift at the same time to give a 5" lift?
you would need caster correction arms to suit a 5" lift at least
Time to create page: 0.217 seconds
