speedo
  • punch
17 Jun 2009 15:39 - 17 Jun 2009 22:39 #805 by punch
speedo was created by punch
aving problem's with my speedo, not getting nothing on it, could it be down to deep water or would that just bugger the sencer ? speedo not even showing milage ?
Last edit: 17 Jun 2009 22:39 by punch. Reason: bad wording
18 Jun 2009 05:27 #808 by mlines
Replied by mlines on topic Re:speedo
Despite the harsh environment under the car I have not heard of anyone having a sensor fail.
I would guess that you have caught the wires on something and damaged them. Crawl under the car and take a look at the rear output end of the transfer box. You will see the sensor and its wires coming out and joining the cat through a white plastic connector. check the wires are all ok.
  • punch
18 Jun 2009 10:39 #809 by punch
Replied by punch on topic Re:speedo
hi martin thanx for the fast reply, i'v been under n checked the sencor n it seem's to be fine ., think the next step will be to trace the wire's back to the speedo ., thought i'd ask as i wasn't sure if it was a commen fault on the jimny ., i'v been puttin off doin it as i'm buildin the rocklobster t box con at the min and will ave to mod the pick up when i fit the new box ., many thanx for ur help
Rich
