Jimny King Pin Modification Idea
23 Nov 2026 19:47 - 23 Nov 2026 19:49 #265612 by Alastair
Hi,
Having gotten a bit fed up with adjusting the kingpin bearings on my 05 Gen 3, and trying to judge the correct shim stack to extend the adjustment intervals but not crush the bearings, I looked on the /net and found “Adjustable” upgrade kits.
(Can anyone vouch for these kits or are they a waste on money ?)
Anyway, it got me thinking… “Has anyone ever considered designing an upgrade kit that uses something like a Bellville spring stack to achieve the perfect pressure and hopefully extend the adjustment intervals to years rather than months ?
The beauty with Bellville spring stacks is that they are almost infinitely adjustable and the correct pressure can be set on the bench before fitting, so (in my case) I don’t spend my morning scrabbling around on a cold concrete floor, getting Farmer Giles.
Feel free to point out any errors in my thinking.
I look forward to hearing your thoughts.
Last edit: 23 Nov 2026 19:49 by Alastair. Reason: Grammar
24 Nov 2026 06:16 #265616 by Lambert
Interesting idea and don't let me stop you but for the most part kingpin bearings are usually failing from water ingress as a result of the big outer main seal being a dust and debris seal to keep bigger nuggets out. It's not that common for there to be surface wear in the bearings elements. It's also not uncommon to have seat regression and other damage be caused by heavy off road use. But yeah look into it further and keep us updated.
24 Nov 2026 06:34 - 24 Nov 2026 06:36 #265618 by yakuza
havent seen how this technically have been solved, wouldnt it poke out more?
Generally conical disc springs are considered a good technical solution. the spring pressure can be adjusted by eihter grinding down discs or with a threaded contraption. Usually SKF and other bearing suppliers generally would recommend a bit too low basic load / preload for conical bearings. Mostly too low bearing loads is what make the bearings wear out but then it is also from high rpms too. I have had good experience (at work building gearboxes) with doubling the basic pressure for these bearings as it is the no load condition that wear them out.
I have used screw springs and sometimes either doubling the number of springs or increasing the spring rate.
But on a jimny you cannot have too much pressure as the steering would get too tight.
I would say that especially the bottom bearing will have little weight from the car, will get most water and contamination, and must be given special attention to both sealing and lube and be given most of the preload, but the setup in a jimny would mostly even out the preload.
I have driven my jimny approx 100000km's and have changed all the bearings once or twice and adjusted maybe twice after that. So rarely i do not remember excactly. I run a fully loaded car at or above its weight limit, use it in sand and mud and with 235 tyres.
could it be something else is wrong?
Last edit: 24 Nov 2026 06:36 by yakuza.
24 Nov 2026 07:45 #265619 by yakuza
ore4x4.pl/en/other/2471-adjustable-king-...y-5904734098263.html
I found these.
I worry they would rust and let in water.
Adjusting them after a few years without servicing the lube, seals and bearings could be like wetting your pants to keep warm.
26 Nov 2026 06:09 #265625 by Busta
I'm interested to know why yours need adjusting so often. My bearings last about 20,000 miles before degrading to the point of letting axle oil out. I don't use any shims and haven't felt the need to adjust anything in-between. 2003 on 130,000 miles.
26 Nov 2026 11:09 #265626 by facade
I can't really see any point beyond initial pre-load adjustment, and you can do that with shims, but generally stuff is machined properly to tolerance in Japan and they just fit and work.
If the bearings wear enough to have any noticeable play following initial set up then adjusting them is just sticking a plaster on a broken arm, once they have gone through the surface hardening then they are scrap, it isn't like a plain bush that you can just tighten up.
The only use case I can see is if the outer races weren't fitted fully home and they have seated fully after a few miles.
What scraps the bearings is rusting of the lower race from water getting past the dust seal, which is why mine does not go through water deeper than a couple of inches.
Time to create page: 0.096 seconds
