Towing advice please
3 days 6 hours ago #265573 by a.dutton@hotmail.com
Hello all.
Looking for advice for towing please. I have a 2016 Gen3, OME 2 inch lift, 215/75/15 falken wildpeak tyres 30mm wheel spacers, Quaife front and rear. About 120kg of modifications in total including awning, rock sliders and under body protection.
Wanting to "overland" morocco and the balkans with it. I simply didnt have the available payload without stripping all the Mods off the vehicle. So I have bought a Penpod utility trailer with ARB Simpson rooftop tent.on trailer. 1300kg max capacity with brakes. Fully loaded weight of set up will (I hope) be about 900kg. 75kg towball weight.
I'm thinking its going to struggle, particularly on Hills.
Im wanting to ask advice from those of you with towing experience what modifications you would recommend to improve
towing. would going back to standard 205/70/15 tyres help ? is altering the gearing worthwhile ? setting it up to have low range in 2wd ? larger brakes ? or would you say none of this is necessary go with the set up you have, its not worth the modifications.
The idea is to stick to decent..ish roads while towing. Use the trailer set up to basecamp, then go off with the jimny with a light camping set up for the odd night away from the basecamp.
I have a lighter set of Gen4 steels with the original Dunlop grandtrek AT20 tyres (195/80/15). I cant think why those may be better to use but just mentioning it in case this smaller, lighter wheels could help. Im open to changing the Tyres on the steels to another size and type if there are worthwhile advantages for towing.
Any advice would be appreciated.
Thanks
Andrew
3 days 4 hours ago #265574 by Lambert
Replied by Lambert on topic Towing advice please
Generally speaking less weight in the prime mover and smaller diameter tyres are going to do the most to make towing viable. Better braking isn't the be all and end all as the trailer is braked and doing it's share. Not that it's a waste of time improving brake heat management especially as you already have quite a heavy setup. But I would definitely recommend going back to the 205 70 tyres as they are the easiest way to adjust the gearing in the right direction, this also helps braking as the lever effect is reduced just like it is for the torque application to the ground. Also for touring I'd wonder how necessary the rock slider was verses it's weight penalty especially with a 1.3 towing 900kg.
For reference I am a shepherd and very regularly towing at 1300kg on road and unmade farm tracks, previously with an auto 1.3 and currently with a manual 1.5. The taller tyres that came on ,195's really compromise the extra power, I'm thinking about putting the 205 70 on it to see if it makes as much difference as it should on paper. Oh and I think that the nose weight is 50kg max, it's what is on my 2 towbar plates.
The following user(s) said Thank You: a.dutton@hotmail.com
3 days 3 hours ago #265575 by a.dutton@hotmail.com
Hi. Thanks for your detailed, helpful reply. The trailer max noseweight is 75kg. The towbar Im fitting is matched at 75kg and my understanding is that 75kg is the cars max noseweight also, so all 3 tie up. I also understand that its best to have noseweight at 10 percent of the total trailer weight. I will try and get the weight down to 750 but in order to keep everything legal Ive had to basically empty everything from the vehicle into the trailer. Im considering not using the rooftop tent because its 60kg. I take your point on the rocksliders, at 43kg its a lot. I'll swap out the 195/80/15's on the steels for the 205/70/15 size. Thanks for your help.
2 days 11 hours ago #265578 by saxj
Replied by saxj on topic Towing advice please
Stock size tyres will help, but travel lighter. That trailer is way too heavy for a Jimny.
Time to create page: 0.087 seconds
