Five door Jimny, auto or manual?
23 Aug 2026 08:48 #265137
by 300bhpton
If it was 1996, then a 4 speed auto might be ok. But in 2026 it has to be a major downer really. Even more so when coupled to a wheezy 1.5 litre engine.
I think the only way you'll know for sure is to drive one, but the performance must be glacial. I bet you'll struggle to beat some lorries away from a round about. Esp if you actually use the seats or load it up.
70mph cruising, well you know how 3 door manual does here. I thought mine was fine, although it was happier at more like 60-65mph. The 5 door is heavier and an auto has a worse final drive, so I would expect it to be slightly worse if you truly want to cruise at a real 70mph+
I actually like the idea of the 5 door, but the execution I feel is lacking. Its heavier, but has the same power, so in real world it has less power to weight. It still uses an antique gearbox. And it has the same size wheels, so off road performance is massively compromised with far worse breakover angle. The 3 door liked to drag its belly (transfer case and radius arm mounts) on the ground enough. The 5 door must be truly terrible on any sort of undulating off road terrain in this regard.
I suppose the other way to look at it. Apart from counting the number of doors, the 5 door appears to everything the the 3 door does but worse.
Some good info in this review:
Plus highlights a bit of a handling flaw, skip to 14min 10 sec to see what I mean.
Replied by 300bhpton on topic Five door Jimny, auto or manual?
Looking to buy a five door Jimny for my business. Mainly because
a/our 2020 three door has been totally reliable
b/l want to get out of diesel vehicles
c/l like driving the three door but it's too small for my business use.
There's a few places offering imports and prices have come down.
My only question is, auto or manual? l've never driven the auto but l had a Defender and got used to not having to change gear.
l know there are people on here who drive the new Jimny auto.
ls it smooth, fast enough, nice to drive? l am not bothered that it's slower than the manual, so long as it's good enough. As my day is spent driving between customers in the city.
Do the rear seats fold flat to the floor?
ls it okay on the motorway? As in, can keep to 70mph without changing down all the time.
I can't get a test drive so will have to choose "blind" and from recommendations on here.
23 Aug 2026 14:43 #265143
by fordem
This was one of my concerns, in fact the second most important (the first was how much luggage I could get in the boot without folding the rear seats).
It's not as bad as it would appear on paper, and in fact, the first thought in my mind, literally within the first thirty seconds behind the wheel, was "hey, this is not bad!!"
Test drive was a Wednesday, down payment was the following Monday and I drove it home on the Friday - two years later I have very few regrets.
Question for you - when you say the automatic has a worse "final drive", what are you referring to? The ring & pinion ratio or the overall gearing? If you look at the ring & pinion ratio, yes, the automatic is a 4.3:1 compared to the manuals 4.1:1, but, factor in the transmission & transfer case ratios and the differences are insignificant.
In my experience, pulling away from a standstill, it's no slouch, that said, overtaking at a reasonable speed is a different thing, you pretty much have to floor the throttle to force a kick down to third, yes, a larger engine, say a 2.0 (which is what I was driving before) would have been nice, but the truth is I rarely miss it.
Replied by fordem on topic Five door Jimny, auto or manual?
- Thank you received: 1999
23 Aug 2026 17:19 #265147
Replied by Lambert on topic Five door Jimny, auto or manual?
Antique gearbox? Nah sorry. 6 speed plus automatic boxes are really only useful for bragging rights and keeping a diesel in its power band. On something that can rev past 3750 rpm it's really hard to justify all those extra gears are superfluous. Add in having a torque converter instead of a robotic clutch system and 4 is fine. And also don't conflate a modern computer controlled automatic with a torqueflite out of a range rover they are not the same.
- The Coil Spring
- Senior Member
- Thank you received: 6
23 Aug 2026 23:47 #265149
by The Coil Spring
Replied by The Coil Spring on topic Five door Jimny, auto or manual?
I drove a 3-door Gen 4 AT for about 500 km and indeed it was like going back to 1996 (but maybe that is a good thing?), but I don't do cities and don't do overtaking, so can't comment on that. However, you will notice a higher fuel consumption than MT.
My 2002 Ignis (4x4) has an AT and uses same engine as Jimny gen 3 so I guess the autobox will be quite similar. I am pretty sure I can feel it shift 4 times when going 0 -> 90 km/h, which makes it a 5-speed, but all the talk here is about 4. Is it a 4-speed + overdrive?
24 Aug 2026 03:24 #265150
On the gen3 auto it's 123 are under driven, 4 is over driven and 4 also has the torque converter lock out so it feels like an additional half gear but it's just the difference between the converter slip. Assuming that the bands aren't slipping and the box is generally working as it should.
- The Coil Spring
- Senior Member
24 Aug 2026 10:50 #265152
by The Coil Spring
I see, that makes sense. The "5th gear" does indeed feel like being a half step up, which would be the torque converter lock up doing its locking thing, right?
But what does the Overdrive Off button do? Apart from initiating the upshift at higher revs, it still feels like a 4-speed. So is it 1 2 3 + a torque converter lock up?
Time to create page: 0.210 seconds
