Best use of budget
13 Jul 2026 15:50 #264924 by Lambert
Best use of budget was created by Lambert
I'm going to set various budgets for modification and I'm interested to see how you would spend it. Sooooo. First off  sub 10 pounds, I'd maybe air freshener. Next sub 50 pounds maybe a headlight bulb upgrade.  Next sub 100 pounds maybe some under side guard. Now sub 500 pounds maybe tyres. Then sub 1000 pounds maybe a traction aid. Finally over a 1000 pounds maybe a selection of overlander options.
So over to you, what would be on your list?
13 Jul 2026 22:30 #264926 by yakuza
Replied by yakuza on topic Best use of budget
Sub 10 unsnagable Phone charge cable
Sub 50 UV-5 mini uhf /vhf radio.
Sub 100 vintage stereo for the SJ
Sub 500 polish made wide wheel arches
Sub 1000 low gear transfer case gear set
Above 1000 31" tyres
14 Jul 2026 18:10 #264929 by major clanger
Replied by major clanger on topic Best use of budget
I'd spend the lot (if I had it) on the purchase of a Flux Capacitor so I could go back to a time where I was not expected to swallow quiet so much BS on a daily basis.
15 Jul 2026 03:26 #264930 by Lambert
Replied by Lambert on topic Best use of budget
Don't worry about it, in ten years time you will look back to now and think fondly of how these were such simple and glorious days. And in a hundred years no one will remember.
15 Jul 2026 07:59 #264931 by Roger Fairclough
Replied by Roger Fairclough on topic Best use of budget
In a hundred years time, the human race, as we know it, will cease to exist.
In it's place there will be a form of politicians, shuffling about in deep dark underground caverns all muttering "it wasn't my fault".
So yes, enjoy it whilst you can, it will only get worse from the day we lost the cup.
Ha ha ha.
Roger
15 Jul 2026 10:55 #264932 by Busta
Replied by Busta on topic Best use of budget
This is based on the things I've done to my own 2003 Jimny:
Sub £10 2wd low-range switch
Sub £50 Replacing vacuum hoses with PVC, routed along the brake lines
Sub £100 Underseat subwoofer
Sub £500 BFGoodrich KM2 (yes I know they cost a lot more than this now)
Sub £1000 Quaife LSD
And I'd like to add a category if I may.
Best free mod: Welding the front diff.
Time to create page: 0.257 seconds
