O2 sensor part number MY99?
09 Apr 2026 20:00 #264216
by Orchid70
O2 sensor part number MY99? was created by Orchid70
Hi all
I have tried to find out correct part number for the lambda sensor. Can someone help me with it.
They sell sensors with too short wires. And bot pre- and post cat sensors. This car only has one. And the wires needs to be at least 400 mm lång. To reach the connector on the right hand side from the drivers side (LHD).
At the moment there is some no name lambda sensor mounted and the wires are extended.
I have check engine light on and blink code 13.
- Thank you received: 1998
10 Apr 2026 03:16 #264217
Replied by Lambert on topic O2 sensor part number MY99?
Hi. If you send Martin in the shop in the top banner a message with your vehicle details he should be able to quote for it if it's available.
- The Coil Spring
- Senior Member
- Thank you received: 6
10 Apr 2026 08:11 - 10 Apr 2026 08:19 #264218
by The Coil Spring
Replied by The Coil Spring on topic O2 sensor part number MY99?
Have you tried entering the VIN into the large part sites?
www.partsouq.com
www.megazip.net
www.amayama.com
www.partsouq.com
www.megazip.net
www.amayama.com
Last edit: 10 Apr 2026 08:19 by The Coil Spring.
13 Apr 2026 19:34 #264232
by Orchid70
Replied by Orchid70 on topic O2 sensor part number MY99?
Yes - never works with Swedish VIN numbers
- The Coil Spring
- Senior Member
13 Apr 2026 23:07 #264233
by The Coil Spring
But there is a most fabulous website not far away called Bigjimny. There you can identify the "Type" of your Gen 3:
www.bigjimny.com/mediawiki/index.php/Man...pes.22_by_VIN_ranges
Partsouq groups the various Jimny part drawings according to "Type" (mine from 2012 is a Type 8, typ).
14 Apr 2026 01:49 #264234
by Orchid70
Vin is: JSAFJB33V00108717
So Type 1.
Could this be the OEM: 18213-50G01-000
And this be correct: ESEN SKV 09SKV139
So Type 1.
Time to create page: 0.600 seconds
