manual locking hubs
08 Apr 2026 20:20 #264207
by mag
manual locking hubs was created by mag
Hi all , i`m sure it`s been asked but I can`t find it , if replacing the auto hubs with manual locking hubs , is it a simple remove the old ones and fit the new ones , would be getting good ones from jimny bits shop , and what grease would you use , is it just a light smear or pack it full , I`m no mechanic but looks like a simple job so would rather not pay a garage £150 to fit them if I can do it myself . thanks for any help from this not very technical person
- Thank you received: 2004
09 Apr 2026 03:25 #264208
Replied by Lambert on topic manual locking hubs
They need the littlest bit of lubrication. Fitting is straight forward just don't go mad tightening the hardware as the cone washers on the hub side are sintered and quite delicate and the little bolts for the covers are tiny, I'd also put some kind of anti seizure compound on the little bolts too as they try and corrode to the covers and can be brutal to remove. Otherwise you will need to either bridge the vacuum pipes up by the solenoid block under the battery or bridge the wires on the solenoid. The vacuum pipes are easier to put back to standard if you need to.
The following user(s) said Thank You: mag
09 Apr 2026 07:58 #264210
by Busta
Replied by Busta on topic manual locking hubs
Physically fitting the hubs is straight forward but whether or not 4wd works afterwards is not guaranteed. What year is the Jimny and what is the reason for fitting manual hubs?
12 Apr 2026 07:39 #264228
by mag
Replied by mag on topic manual locking hubs
All works fine at the moment but having owned 4 jimnys
the lst one had manual hubs and i liked the fact you knew the 4wd would work and nice to have low box 2wd option
13 Apr 2026 08:57 #264229
by Busta
I ask because manual hubs won't always guarantee 4wd works. On all Jimnys, but more so on post-2005 cars, there are a number of other things that can cause 4wd not to work even if the hubs are locked. And manual hubs aren't 100% problem free. I have 2wd low with vacuum hubs, it's a fairly simple modification to do.
