Car cover
7 months 4 weeks ago - 7 months 4 weeks ago #264030 by Lambert
Car cover was created by Lambert
Whatcha.  It's occurred to me that while I have waxed and coated temeraire to keep the worst of the weather off she is still obliged to sleep outside. I have looked at a storage tent but unfortunately because of how my drive is laid out that would put it past the front elevation and therfore foul of planning. Sooooo, I am now looking at a proper cover for her. I accept that you get what you pay for but are there any out there that are either sufficiently form fitting or well lined enough that they won't rub through the paint when it's windy which it always is living on top of a hill? I'd prefer not to have to power said cover like the pressurised bubble ones.
Last edit: 7 months 4 weeks ago by Lambert.
7 months 4 weeks ago - 7 months 4 weeks ago #264031 by jlines
Replied by jlines on topic Car cover
My feeling based on my experience with boat storage covers and car covers is that they all Rub and would cause potential damage in some ways (I took a big winter cover off a boat today with the owner and he noticed that it's worn through his Gelcoat!). I was told by my car detailer that he doesn't like car covers due to damaging the paintwork. For my outdoor jimnys though I did buy a cover as we have a a lot of trees around and this time of year the pollen starts so I like to keep the car covered up that I won't be using. I bought just a cheapish generic car cover which does the job for a temporary cover up but I wouldn't like it in a very windy situation. I would have no cover during high winds. One tip I would give is to buy a cover bigger than the car as even with my latest cover it's still a bit small. You can get fleeced lined stuff but that presents its own challenges such  as being heavier to get on and off the car. Also you would have to carefully watch that it doesn't pick up any grit in the fleece lining. Whilst the cover on my car is lightweight it does take me & my dad to carefully place the cover over the car to avoid it going on the floor or dragging it across the car.
So I think overall the best practice is to have no cover but a well protected polished car that's easy to wash off. If you want a cover then you want something lightweight thats easy to put on but also has good tie downs to keep it tight to the car rather than it flapping against the car and if it does look windy and too much for the cover to handle then just take it off.
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Last edit: 7 months 4 weeks ago by jlines.
The following user(s) said Thank You: Lambert, gv42
7 months 4 weeks ago #264032 by Lambert
Replied by Lambert on topic Car cover
Thank you. That rather confirms my worries that they can't avoid doing some damage to the paint and the more I take it on and off the higher the potential for damage especially as I would be doing so on my own. Hmmm.
7 months 4 weeks ago #264033 by jlines
Also another issue with covers if your keeping the car covered up for a long period is the issue with dampness and mould inside the car. I know Bigjimny suffers this without a cover which is why we have a dehumidifier running inside it. It would be worse if it was covered up. We see this a lot with boats at my work and usually the wrapped up boats are in a worse state than the ones that didn't do anything!  This wouldn't be an issue if your using the car often.
2018 JB43 SZ4
2023 JB74 LCV
7 months 4 weeks ago #264036 by Lambert
It's almost worth biting the bullet and getting consent for a car port from planning, probably cheaper too having most of the materials in stores. The lengths we go to for our precious jimny!
7 months 4 weeks ago #264039 by DrRobin
Replied by DrRobin on topic Car cover
I bought a cover for my other car, a good one, breathable with a soft lining. It was tailored to fit but still flapped in the wind so had to run some extra ropes over it.
I only used it for about three winters, it worked fine, but the paint was dull when you took the cover off and needed a really good polish.
To be honest, it was better when the wind could get underneath it kept airing the car out.
Parked in a less windy area and not fitted too tight I would say it worked fine. Parked on my driveway at the end of the wind tunnel it was less than successful. So rather than put a cover on the car I opted to use it through the winter.
Time to create page: 0.086 seconds
