Battery not charging
16 Nov 2025 15:56 #262765
by gillett02
Battery not charging was created by gillett02
Hi, I have tried to find if anyone else has posted about this but I can't seem to find any solutions.
Initially my battery wasn't charging and diagnosed it down to a faulty alternator. As such I changed this to a higher amp version, this initially fixed the problem and it was charging.
Then I was having issues with the battery holding its charge, I replaced this as it was fairly old anyway. Again this was fine temporarily and it was charging.
The battery light was on during all of this but it was still charging so didn't really see an issue with it.
Now it seems that the battery is not charging whilst the engine is on. When I put the voltmeter on whist the engine is on its sits at around 11.7v and slowly drops overtime.
I have checked and cleaned all the grounds to the body and even did a temporary earth from the battery to the engine block to see if that was the issue but nothing changed.
I have completely disconnected the alternator and just spun it with a multimeter on and the voltage does go up slightly.
I have also tried the connecters on the back on the alternator when the ignition is on and that shows voltage when on and doesn't when the ignition is off.
I have put the multimeter directly to the alternator whilst the engine is on and this is also showing around 11.7 volts, the same as the battery.The fuse from the alternator to the battery is not blown either.
I think I have tried everything I can think of as to why it's not charging but I'm just at a bit of a loss at this point so was wondering if anyone has any suggestions.
Cheers,
Adam
Cheers,
Adam
- The Coil Spring
- Senior Member
- Thank you received: 6
16 Nov 2025 16:37 - 16 Nov 2025 16:53 #262766
by The Coil Spring
Replied by The Coil Spring on topic Battery not charging
Suggests to me that the new alternator isn't working either. The 11,7 V you are measuring is power being drawn from the battery. 16-18 V should be normal output, if I am not wrong.have put the multimeter directly to the alternator whilst the engine is on and this is also showing around 11.7 volts, the same as the battery.
Last edit: 16 Nov 2025 16:53 by The Coil Spring.
16 Nov 2025 16:47 #262768
by gillett02
Replied by gillett02 on topic Battery not charging
I thought that could be the case that's why I disconnected it and spun it by hand and got a voltage output. It was only around 1v but obviously I cant spin it as fast as the car would 😂
16 Nov 2025 18:21 - 16 Nov 2025 18:48 #262771
Replied by jackonlyjack on topic Battery not charging
Should be seeing around 14.4volts when engine is running
You could give the wires a wiggle to see if reading on multi meter changes
Type fitting 100amp alternator to a suzuki Jimny
Into Google Ai has some suggestions about wiring changes
Last edit: 16 Nov 2025 18:48 by jackonlyjack.
- Thank you received: 667
16 Nov 2025 23:58 #262773
Replied by DrRobin on topic Battery not charging
JackonlyJack is right, about 14.2 volts with the alternator charging, even a dead battery will get to this.
So suspect another faulty alternator, or possibly a voltage regulator if your car is fitted with one.
Is the alternator belt the correct tension?
17 Nov 2025 02:38 #262774
by gillett02
As far as I'm aware it doesn't have a regulator, sorry I should have said it's a 2005 automatic model in my original post.
Time to create page: 0.195 seconds
