Heated mirror retrofit
31 Oct 2025 08:10 #262533 by Lambert
So because apparently suzuki don't think it's a safety issue to be able to see out of the side mirrors at this time of year on the van version I'm interested in retrofit mirror heaters. Obviously it will need elements but is the loom already there or is it going to be a whole standalone thing?
31 Oct 2025 08:20 #262534 by mlines
Replied by mlines on topic Heated mirror retrofit
All the wiring is in place all the way into the door behind where the mirror fits.
Not a cheap update but to you can buy the complete mirrors from the SZ5 and plug them in.
You can probably buy the glass insert 84730-77R10 and 84740-77R10 and create the wire through to the inside of the door
31 Oct 2025 09:04 #262535 by BALDY60
Replied by BALDY60 on topic Heated mirror retrofit
as Martin says, i bought the mirrors from Bigjimny and swapped them both over, it's great being able to see behind in the misty morning now.
31 Oct 2025 13:49 #262539 by DrRobin
Replied by DrRobin on topic Heated mirror retrofit
Van drivers round our way don’t appear to use mirrors before pulling out in to your lane.  Perhaps that’s why Suzuki decided not to fit heated mirrors?
Do you get a heated rear window or is that missing as well?
On a slightly separate note, I have had my other car (a soft top) for 18 years and always thought it was strange that the dashboard has a heated rear window switch when the heater element is fitted, just assumed it was a common dashboard.  It was only last winter, I accidentally switched it on and the wing mirrors cleared, seems it has heated door mirrors and that is what the switch is there for.
I always gave them a scrape or used warm water/deicer.
Robin
31 Oct 2025 14:25 #262540 by Motacilla
Replied by Motacilla on topic Heated mirror retrofit
Your message reminded me that I have the heated mirror elements in a box somewhere, never got round to fitting them.
It is a little more complex if you want to use the factory plug -- there is room for the new wires, but you have to find an appropriate cable end. But if you just directly connect wire-to-wire, it is easy and will function without further changes.
31 Oct 2025 23:14 #262548 by jlines
Replied by jlines on topic Heated mirror retrofit
The LCV does have a heated rear window. I had a similar situation with my old Range Rover Evoque where for a few months I had no idea it had a heated steering wheel until one day my sister wanted to test drive my car as she also wanted one and asked what this button did on the steering wheel. I said I don't know and she pressed it and it lit up orange. A couple of minutes later she said the steering wheel was warm. Whilst it was pointless for most of the year it was good during the cold winter months along with the heated seats. Its a shame the LCV doesn't have heated seats.
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
